peavey studio pro 112 silver stripe .. question
Discussion in 'Amp Central Station' started by popthree, Aug 19, 2019.
  1. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    i picked one up the other day. alright little amp but dang, it's so loud. i expected to use channel 1/clean channel primarily but the problem i have is that its too loud at its quietest setting for my normal in home practice level. anyone else run into this ? the volume goes from dead silent to almost too loud somewhere between 0 and .5... so below (1) on the volume dial. i'm having to ride a volume pedal to keep it down where i want it. seems quite odd, and is kind of annoying.
  2. Wally
    If you don’t do tech work, you have bought something into which you will have more than it is worth...and that is fine as long as you like it. Old wisdom....check the water before diving in.
    LuthRavin likes this.
  3. wildschwein
    wildschwein Tele-Afflicted
    Perth, Western Australia
    Sounds like you should have bought a Peavey Rage instead.
  4. popthree
    No efx loop
    wildschwein likes this.
  5. popthree
    guess so.....but
    Ive never encountered an amp that was too loud when dialed down below 1, even a twin can whisper pretty.
  6. Wally
    There are those amps that do that. The Blues/Hot Rods are infamous for having a sweep that brought volume right away. In those, one could change the V1 tube and correct that error while making the amp much better in all respect, imho.
    This PV of yours could be acting in the manner it was build, or there could be a problem. ??? Maybe someone who has one can respond. I haven’t encountered a Peavey SS amp that did what yours does...but then I never played them enough to notice that it cannot operate at a whisper...as some TR’s can do. Some have an odd taper to the channel volume controls that might best be changed...especially if one pulls the master volume circuit out.
    Good luck with it.
  7. popthree
    Using the low gain input helps some. I had better luck with it tonight. Also ran my looper and delay through the efx loop and that seemed to help as well. It sounds nice enough for my ears I think.
    Wally likes this.
  8. Wally
  9. rangercaster
    Knoxville TN for now
    Effects loop volume control should cure it ...
  10. hrstrat57
    hrstrat57 Tele-Afflicted
    Rhode Island
    In my experience anything Envoy and up in the silver stripe/red stripe era makes a lousy practice amp.
    Envoy/ Studio Pro are killer gig machines tho...but way over the top for in home use.
    I have a RS Envoy presently and the gain Channel is absolutely insane loud. It’s a grab and go little monster tho.
  11. Millebern
    Millebern Tele-Meister
    I respectfully disagree. I just picked up a Studio Pro red stripe and I find it sounds great at low volumes (bedroom level). I don't use the drive channel as I prefer getting my dirt sounds from an OD pedal which I find sounds great with this amp. With the Studio Pro I just purchased, there isn't that spike in volume the OP mentions.
  12. popthree
    Yeah I have owned a studio pro before, albiet the older, original model with the 2 wide vertical silver stripes. It was a decent practice amp and probably not really enough oomph for gigging. This newer one is a whole other animal.
  13. popthree
    After working with this amp for a week I gotta say, it sounds great, but it's too loud for my use. I think I'm going to flip it and go another direction. Pity because this thing is clean and appears to have very little usr, especially given its age. If I was still a gigging player this would be a workhorse of an amp for sure.
  14. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    My Classic 30 can be too loud.
    I have been having a blast with my multieffect in the loop.
    I run the amp gain about 3 and Reduce the volume with the global multi volume.
  15. DougM
    DougM Poster Extraordinaire
    Honolulu, HI
    I've had some amps and pedals that do that, because the value of the pot used for volume has a taper that's too extreme, and increases too quickly for fine adjustments in its lower range. It may be because it's a linear taper pot instead of audio taper. A couple of Klon clones I have are like that, going from zero to blasting in the lower 25% of the level pot's range.
