drewpennell2684
Hey there
Anyone selling a Special 130?
I live in the Batlimore MD area
thanks!
thanks!
It sounds to me Like those jacks in the rear of the amp are dirty, thus preventing your new foot switch from working properly. This is a common issue and very easy to resolve. Since you stated you had cleaned all the pots and didn't mention anything about cleaning any of the jacks, I can only assume that may be your problem. Spray some DEOXIT or other good contact cleaner onto the tip of a 1/4" plug and insert it into each jack at least 5 or six times, and repeat the process for each jack. If that's the issue, it should take care of the problem. Good luck!Can someone help a guy out here? I purchased a new Peavey foot switch, since this 130 didn’t come with one. No workee, the amp stays on the overdrive channel. The right foot switch button won’t turn off reverb, either. I tried sticking one end of a patch cable in the foot switch jack with the same result. The gentleman I bought the amp from replaced the caps, and I cleaned the pots so the amp sounds great, but I’d like to be able to access the clean channel. Any ideas what the issue could be?
Thanks, but still no switching. I tried a 1/4 inch patch into the foot switch jack, no go; I tried patch cable into power amp in and out, and there are lights on the foot switch, but no switching between channels and reverb stays on. I think we’re off to the amp doctor…It sounds to me Like those jacks in the rear of the amp are dirty, thus preventing your new foot switch from working properly. This is a common issue and very easy to resolve. Since you stated you had cleaned all the pots and didn't mention anything about cleaning any of the jacks, I can only assume that may be your problem. Spray some DEOXIT or other good contact cleaner onto the tip of a 1/4" plug and insert it into each jack at least 5 or six times, and repeat the process for each jack. If that's the issue, it should take care of the problem. Good luck!
At this point, if you hadn't already done so...I'd head on over to the Peavey Forum site and pick their brains. There are quite a few very knowledgeable Peavey Techs and users on that site who may be able to lead you down the right path to getting your amp issue(s) resolved. Good luckWell I brought the amp and foot switch to my local guitar shop. The amp tech is booked out 6 weeks, so one of the guitar techs tried one of his new foot switches on the amp, with the same result: stuck on drive channel, and stuck on reverb. I decided to bring the amp home and do some more research. I'm wondering if there might be an issue on the circuit board, since the leds on the foot switch turn on and off.
I've searched quite a few forums for channel switching issues with Peavey amps, and am not coming up with anything substantial.
