Hi All, have a wiring query and hope someone would be able to chime in.
My current guitar has HH Thornbuckers installed and I am looking to have a single coil split (screw side, coil that is nearer the neck) from the neck humbucker in position 4 using a trimpot so that I can decide what resistance level would be the sweet spot (volume loss vs single coil tone).
I brought my guitar to the guitar mechanic and the feedback that I got is that the slug/north side is the coil that is 'always on' with the screw side that gets added into the mix (with the trimpot modification) and having the screw side as the coil that is 'always on' is not possible.
Does anyone have any ideas if it would be possible to have the screw side (that is nearer the neck) always on and have the slug side added into the mix instead, without having to use a push-pull pot or going out-of-phase?
Thanks.
Thanks.
