Parallel Fuzz Experiment
Discussion in 'The Stomp Box' started by Muzik4Machines, Nov 19, 2015.
  1. Muzik4Machines
    Muzik4Machines TDPRI Member
    quebec
    i had my LS-2 around so i decided to try parallel fuzz instead of stacking
    the mid scoop of the muff and the mid-heavy nature of the orange make a really nice match in an "on the verge of breakup" amp, and a full on destructive noise machine in a driven amp (in this case via the FZ-2 Boost)
  2. FenderLover
    Minnesota
    I don't usually get that heavy, but I use an OD and Fuzz in parallel, and put the volume pedal in series with the Fuzz (instead of the input). You can pedal down on the Fuzz to morph between OD and OD+Fuzz blend (set the fuzz output a little higher). Fun stuff.
  3. Muzik4Machines
    quebec
    i tried it in a "song"
    edit: i don't understand why it double posts the video
