paper shim and long-term neck health
Discussion in 'Tele-Technical' started by jc77, Apr 23, 2021.
  1. jc77
    jc77 TDPRI Member
    I love my guitar's current set-up -- it's been about a month, and I feel like it's never been more intonated and playable. (Maybe it's the humidity level -- thank you April.)
    Anyway, to get this latest iteration of my guitar (a partscaster: restored MIM Joe Strummer neck, 80's USA body) I put a tri-folded piece of notecard at the bottom of the pocket.
    I've read both sides of the debate: leaving a space will give the wood an opportunity to swell & warp; vs. people have been using slivers of business cards and matchbooks for 60 years, and that's just the Way.
    I'm considering getting a Stew Mac angled full-pocket shim (or a couple of them, to experiment), out of paranoia -- swollen and warped, no thank you! -- but then I'm back to square one, or ground zero, dancing the truss rod/shim/saddle height troika and hoping to hit the golden ratio. I love my guitar, where it is today, and would rather not frig with it.
    Telemasters -- what wisdom can you share on this topic? Thank you in advance.
  2. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    IMO...I've seen strats and teles come from the factory with partial shims and I don't think it will matter in the long haul. A small shim won't leave enough 'bare' wood to swell or warp I wouldn't think.
    I've you're happy with the setup, leave it as is until you're not happy with it. Could be many years!
  3. trapdoor2
    trapdoor2 Friend of Leo's Gold Supporter
    Sauth Carolina
    I have banjos with card-stock shims that are over 100yrs old. Hasn't affected the neck joint at all. Yah, different joint but still, the wood hasn't moved.
    Then there's the old adage: "If it ain't broke, don't fix it."
    OTOH, a tri-fold piece seems very thick to me...and I would be similarly bugged by it...but because of the limited the contact area, not for any warps or wood movement. However, it is an electric guitar (ie, a stick with strings), it isn't acoustic and probably is unaffected by how solid the neck joint is...esp. if it is working fine.
  4. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Don't obsess over it. When your guitar is working correctly, spend time with it making music.
    Too many people spend too much time futzing around with a non-broken guitar and 'fixing' it until it is broken.
    I have lost count of the number of guitars I've had to fix because their owner decided to fix it themselves. And there's no shortage of damaged bodies and necks Fleabay and Reverb. Virtually every seller claims, "I bought it in this condition blah blah blah," because they're too embarrassed to admit they hoop-a-jooped it themselves.
    Play your guitar!
  5. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    So why are you messing with it ????
    If there is no issue with the neck angle vs. the body/bridge (which is the shim purpose) than
    all is good.
    So if a person doesn't have a cut, do they still wear a band-aid?
    nojazzhere likes this.
  6. chris m.
    Santa Barbara, California
    It won’t hurt it. Leave it be.
  7. SRHmusic
    SRHmusic Tele-Holic Silver Supporter
    North Carolina, USA
    I ended up getting a few of the Stew Mac ones, which worked well. I like the idea of full contact, and wood in there rather than paper. But short of any science on this, do what you think is best overall for you (time, budget, hassle vs worry).
    Boreas and Texicaster like this.
  8. Laren
    Laren Tele-Meister
    West Somerset
    If it's try-folded and you're worried about a gap then try-fold it like this (if my useless drawing helps) :twisted:
    JSMac likes this.
  9. jc77
    jc77 TDPRI Member
    That drawing is tops, thank you.
    All -- maybe some confirmation bias here, but yes, thank you, these are the messages I want to hear. I've struggled with this guitar, and feel like I've finally gotten it right, so taking it apart again is really the last thing I want to do. If & when things go wonky, then it will be time to reopen the case -- meanwhile I will be in the woodshed -- practicing I mean :)
  10. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Just because a paper shim CAN be used doesn't mean it should. Is there a reason for the shim? What happens when it is removed? Has the bridge been changed? Is the neck shim covering up another setup or build issue?
    A neck shim isn't going to hurt anything, but if it is going to be permanent, I elect to spend a few bucks on a tapered wood shim. What is the downside?
  11. ElJay370
    ElJay370 Tele-Afflicted
    Los Angeles, CA
    You don't need the 8 dollar Stew Mac shim.
    If the neck is attached firmly and doesn't move, whatever paper you have folded however many times stuck in there is fine.
    I'm pretty open minded about these kinds of things and will readily concede to "It's your guitar. If it matters to you, then it matters." but I think far too much headspace is wasted on neck shims.... as long as we're talking thousandths of an inch.
    If you're sticking three guitar picks and a matchbook in there to get the action where it needs to be, then it's a problem.
  12. tanplastic
    tanplastic Tele-Holic
    I can see your house from here.
    I had a shim made and installed by a local guy.
    Crudely-shimmed necks with ski jumps at the 21st fret are not unheard of, and I wanted the proper wood coupling, so it was worth it for me.
  13. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    I use cardstock shims for small adjustments. Save the full pocket shims for Bigsby B16 installs and offsets, which need 1 to 3 degrees pitch at the neck.
  14. Crowcaster
    Crowcaster Tele-Holic
    North Dakota
    The more Fender guitars I set up, the more I think they all need a little shim. I know I'm gonna get called an idiot for it, but it works for me. I just use any thin material I find around the house and cut it to shape.
    Get those guitars playing!
  15. Fretting out
    Land of Mary
    I’ve heard/seen evidence that a neck will warp around the shim
    I’ve spoken at length about this with my woodworking father
    We’ve concluded that technically yes it can happen but.....it’s very unlikely to happen every time
    I have a shin on my jazzmaster with a visable gap from the side and no worries from me
  16. archetype
    archetype Fiend of Leo's
    Williamsville NY
    If it needed a shim to begin with, and if it can be set up properly with the shim you put in, it's fine.
    Forget everything you've ever read or heard about shims, warp, swell, and contact area, and play the guitar. It's fine and will remain so when your great, great, great, great grandchildren are staring at that colorful, stringed object and wondering what it is.
  17. Lonn
    Lonn Friend of Leo's
    Indiana
    My 70s Kramer has 6 pieces of this brass used for a shim. From the looks of them they've been there a very long time so I didn't mess with them.
  18. wblynch
    wblynch Tele-Meister
    California USA
    Makes me wonder about the factory micro tilt mechanism. Doesn’t that introduce a gap? And with the pressure only on the centerline, not even across the width, what those implications are?
