PAINT: Pickup Cavity (Conductive)
Discussion in 'Telecaster Discussion Forum' started by giddyap, Aug 3, 2020.
  1. giddyap
    giddyap TDPRI Member
    midwest
    Nope, not Stew Mac.
    What else and where else have you personally purchased conductive paint for pickup cavities?
    LetItGrowTone likes this.
  2. Grendel2000
    Grendel2000 TDPRI Member
    California, MD
  3. LAPlayer
    LAPlayer Tele-Meister
    LA / Denver
    I haven't personally but, the friend of a friend told me that he knew someone.... I forget whether friend or family... who had thought about buying a 1975 American Motors Gremlin an when they took it to a mechanic, they found conductive paint on one of the fenders. Or did they find it one one of their Fenders? I forget. Never mind.
  4. Cam
    Cam Tele-Afflicted
    Canada, somewhere in former Oilville
  5. Urshurak776
    Urshurak776 Tele-Holic
    Charlotte
  6. bls82261
    bls82261 TDPRI Member
    Virginia
  7. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
  8. LetItGrowTone
    LetItGrowTone Tele-Meister
    U.S.
    That is beautiful overkill and I mean that in a good way; conductive paint need not be that perfect, but a coat of real metal really eliminates all doubt.
    I wonder which other products are real metal-in-a-solvent?
  9. 61fury
    61fury Friend of Leo's
    knoxville, TN
    Guitar Fetish crap, zero conductivity with the probes from the ohmmeter almost touching, Maybe I needed more coats?
  10. Ess Eff
    Ess Eff Tele-Holic
  11. giddyap
    midwest
    This might also be a new topic...but...
    Why are guitars not made this way direct from the factory???
    Why is this step not a part of typical electric guitar set-up's performed by guitar techs (or, at least, suggested and quoted)???
  12. Bella
    Bella Tele-Meister
    Portland, OR
    Some do come that way. My 2015 Squier CV50s BSB came with shielding paint, but my Fender MIM 72 Tele Custom came bare.
  13. rangercaster
    Knoxville TN for now
    I used recycled aluminum foil to shield my cavities ...
  14. giddyap
    midwest
    I understand that the cavities must be shielded...but what about the "tunnels" connecting cavities?
    How do they get shielded, or don't they?
  15. TheDams
    TheDams Tele-Holic
    Minneapolis
    when I use conductive paint, I use a q-tip to do the « tunnels » ;-)
  16. SuprHtr
    SuprHtr Tele-Holic Silver Supporter
    Rocket City
    I you can twist the wires or, better, use shielded coaxial wire in the tunnels. Just use the braided sheath as your ground wire. An excellent source for shielded wire is an old RCA cable or headphone cable. My G&L ASAT came with conductive paint and shielded wire in many places that you wouldn't expect it.
  17. Laren
    Laren TDPRI Member
    West Somerset
    You can make your own using graphite powder and acrylic paint (somewhere on YouTube). It won't make your meter go 'beep' but it does give very low resistance. Only trouble is is that it is a messy as hell. I won't be doing it again.
  18. warrent
    warrent Friend of Leo's
    toronto
  19. giddyap
    midwest
  20. Bella
    Bella Tele-Meister
    Portland, OR
    I think he was suggesting using a shielded wire where you'd still need to make good contact between the ground wire and conductive paint on either side of the tunnel. So you'd run the shielded ground wire through the tunnel and affix the exposed gfound wire ends to the conductive paint.
    I didn't use paint on my 72 Custom (I used metal tape). For the tunnels I ran a thin strip of the metal tape through and affixed it to the conductive tape in the cavities thus creating continuity throughout all cavities (you need a multimeter to confirm this). I could have also just used a wire, but since I was already using tape tor the cavities, I stuck with that.
    You'll also want to make sure your pickguard has conductive tape underneath that makes contact with the shielded cavities when closed to complete the faraday cage.
