PA question, not sure where it goes. Need help.
Discussion in 'Amp Central Station' started by gitlvr, Aug 6, 2017.
  1. gitlvr
    gitlvr Friend of Leo's
    Northern Va.
    Hi
    I have a question. Please understand this is a church PA, and a bunch of hands are on it, not just mine. Someone has purchased neutrix speakon cables for the PA because we were having issues with the old cables.
    We are using a Crown 402 power amp. I am coming out of side one of the crown to the first "mains" speaker(SP2), then daisy chaining to the second. Then out of side two of the crown into the first monitor speaker, and daisy chaining that to the second monitor speaker. So that one side of the board runs mains, the other monitors.
    I need to hook up the PA tonight, and would like to maintain that configuration.
    Can I run Neutrix to speaker one, then come out of speaker one with a 1/4" jack, running to speaker 2? Will it run this way?
    I don't have time to run out and buy connectors, we have what we have, and tonight is a song service, I think, so I need the PA up and running by 6 P.M. tonight.
    Here are the specs for the SP2 https://assets.peavey.com/literature/manuals/sp2_specs.pdf
  2. corliss1
    Lansing, MI
    Sure - the connector type doesn't matter in this case. Go speakon -> Speaker A -> 1/4 -> Speaker B. It'll be fine.
    jimash likes this.
  3. gitlvr
    Northern Va.
    Thank you. Working just fine! Much appreciated.
