P90 wiring question
Discussion in 'Just Pickups' started by mrsongbird, Nov 21, 2020.
  1. mrsongbird
    mrsongbird Tele-Meister
    Michigan
    Not being able to leave well enough alone, I snagged a used set of Gibson p90s off of Reverb to throw in my Fender Offset (which has Japanese P90 soapbars in it). I didn’t notice until after I bought them that this specific pair came from a LP Traditional from 2012 with the ability to tap the coils.
    Can these pickups be wired in standard configuration on the offset? Would I just end up taping or grounding the wire for tapping the p90?
  2. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Sure, no problem at all using them like normal p90s.
    I don't know these pickups, how many wires are there com each pickup?
    mrsongbird likes this.
  3. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
  4. mrsongbird
    Michigan
    Note: I don’t actually have the pickups yet, but here’s a picture from the listing
  5. FenderLover
    Minnesota
    In short, you are correct. The tap is just a wire that you will not use. Identify it and tape it off.
  6. AJBaker
    Switzerland
    Can you measure the dcr from the bare wire to the other three?
  7. Si G X
    Si G X Tele-Afflicted
    England
    These sound interesting, I'd be tempted to wire them so you could tap them.... I imagine it may switch them between a 'hot-rodded' sound and a 'vintage' sound.... which would be pretty cool I think.
  8. 1 21 gigawatts
    1 21 gigawatts Tele-Meister
    Same colors as Seymour Duncan. If Gibson uses the same color scheme, solder the red and white together and tape. The black will be the hot while the green and bare are grounds.
  9. Zepfan
    Horn Lake, MS
    Are you sure these aren't P100's?
  10. Zepfan
    Horn Lake, MS
    You may want to take a cover off to make sure they are P90's and not the P100's.
  11. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    I hate letting a good tap go to waste...
    "Are you sure these aren't P100's?"
    I think the "P-90 tapL" sticker might be a cleverly disguised clue...for those sharp enough to catch the implication.
    Zepfan likes this.
  12. Allan Allan
    Allan Allan Tele-Holic
    Illinois
    But what would you tap in a P-90? They're single coil by definition.
  13. AJBaker
    Switzerland
  14. Allan Allan
    Illinois
    Oh man, I would totally hook that up with a push pull knob. You don't have to use it.
  15. Zepfan
    Horn Lake, MS
    Just wondering why anyone would tap a P90?
