P90 pickup height problem
Discussion in 'Tele Home Depot' started by smsuryan, Jul 22, 2018.
  1. smsuryan
    smsuryan Friend of Leo's Silver Supporter
    The Aux arcs
    The body I have is not a full two inches thick, more like an inch and a half. Upon installing the neck I noticed the pickups are standing way above the neck and the guitar would not be playable. I could try to reroute the wood and repaint but that’s something i don’t want to do. What pickups would fit into a standard p90 cavity without the pickup (or the bezel to the pickup) standing that high? Thanks IMG_1681.JPG IMG_1684.JPG
  2. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    I think you could re-route if careful - I would try.
    Tape the top of the body so it doesn’t get scratched up when moving the router over it.
    Hog out cavities to the correct depth with a forstner bit (be mindful of the tip being ~ 1/8” deeper), then buzz it with the router.
  3. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Without the dog ear covers, do the basic pickups fit in the holes you have? The other style of P90 covers don't use dog ears and screw through the body. That might be the easiest way.
    Otherwise, mark around the current pickup covers then cut out with a drill, wood chisel, router, dremel vibration saw, etc so you can sink the whole dog ear down below the surface. Check body thickness you have available if that's a concern.
  4. robinn
    robinn TDPRI Member
    Belgium
    As mentioned, you use the dog-ear style P90s, common for Gibsons. Fender-style guitars are better off with the 'smaller' p90 cases which feature screws in between the pickup poles. You could use those, but then the screw holes from dog ears will still be visible.
    You could also shim the neck, and use a TOM-style bridge you see on Les Pauls. Would be the best solution if the isn't bridge screwed on the body yet (hard to make out from the picture. If it's already screwed in, it seems a little angled though, but then again might be picture).
    Personally, I would go with the TOM-style bridge.
  5. guitarbuilder
    You can also shim the neck up but the bridge saddles may not go high enough. Make a tracing of dog ear cover and make a template the exact size. Then scribe around the inside of the template to score the finish. If you take a pattern bit that is 1/2" deep like the stewmac bit, or a 1/4 "deep"template bit or similar you can rout a shallow cavity to accommodate it.
    https://www.amazon.ca/Milescraft-22...coding=UTF8&psc=1&refRID=JCJ6SS6NE3Y9148WNJ6M
  6. notmyusualuserid
    notmyusualuserid Friend of Leo's
    In the South
    Soapbars. They don't need a deep route.
  7. DrBGood
    DrBGood Tele-Meister
    Sutton QC, CANADA
    That would have been my solution too, but he'll be stuck with the dog ears screw holes.
    It's not for nothing that you never see that kind of bridge coupled with dog ears. There might be a hard lesson learned here. Should have mocked up everything, before starting to screw thnigs down.
  8. MilwMark
    near Arnold's
    Just needs to fill the holes with a flush screw. Looks cool.
  9. Barncaster
    Northern California
    They make separate dog ear surrounds for standard P90 covers. Definitely the way to go in this situation.
    Rob
    robinn, mPacT and guitarbuilder like this.
  10. guitarbuilder
  11. knockeduptele
    knockeduptele Tele-Meister
    London
    All Parts do a dogear cover pair where one is much lower than standard and clears on a Tele at the neck - they are not perfect but they are a fix
  12. trev333
    Coolum Beach,Australia
    you almost have to deck P90's close to the body on Teles..........
    what the hell, just rout deeper holes for the dog ears.... not pretty, though.....;)
    Ahh, but don't they sound great.... :twisted:
  13. DrBGood
    Sutton QC, CANADA
    I actually like that, doesn't look half bad.
  14. trev333
    sleeper guitars those X squiers..... there's no neck pickup rout on the stock body.. a true "esquire"....
    . great necks, too...
  15. TRexF16
    Tucson
    Aren't there shallower dog ear covers available? I think so. Do a search (I'd do it but it's late and I'm about to turn in). Then you can deepen the rout for the pickups themselves and still use the same holes as you've already drilled.
    Good luck,
    Rex
  16. timfred
    timfred TDPRI Member
    Northern CA
    Make flat covers out of pickguard material?
    magic smoke likes this.
  17. screamin eagle
    screamin eagle Poster Extraordinaire
    S. CA
    If you're committed to the dog ear and you don't want to route out the body, I think you're limited to neck shimming and either a wrap bridge or TOM/stop bar.
    Why not just go with soap bar p90's?
    MilwMark likes this.
  18. MilwMark
    near Arnold's
    Nailed it. Very succinctly.
    screamin eagle likes this.
  19. screamin eagle
    S. CA
    Something like this would be cool, but obviously you lose what a traditional tele bridge brings to the game.
  20. screamin eagle
    S. CA
    Maybe you could shim the bridge and the neck. Get someone to machine you a shim of the same material as your current 'chopped bridge' and put it underneath.
