giogolf
Hey All,
I want to test a SD P90 Phat Cat in Les Paul Tribute which for this unfortunate reason has a PCB with all the quick connections.
Now the 490 HB in their now have 4 wires to a Gibson Quick connector and the Phat Cat and other P90 Humbuckers are 2 wires.
Which would be the best or cleanest way to install this in the neck position only?
Can I cut the connector on the neck pickup and just connect the 2 wires to the cut connector (but which 2 of the 5 wires on the connectors do I solder to the 2 pickup wires)
Or
Solder the 2 wires directly to the neck volume pot ( but where do I solder them) and just unplug the neck connector?
Oh, and surely someone will say this.. No, I am not re-wiring controls with new 500k pots and caps to make it traditional..
Thanks in advance
Or
Thanks in advance
