ericjruppel
Hey y'all, I'm new to the community and working on my first build. I'm planning a walnut body with two Epiphone Pro Plus P-90 pickups, and I'm realizing how many decisions there are at every step! I'm planning to use a push-pull pot for my tone knob that will include both .02 and .01 capacitors, to allow for variety in the tone.
I just got the body shaped and rounded off (see image below, I'm in love!), and I'm trying to figure out where I want the pickups located. I thought it would be a simple "follow the template", but I see now there are a lot of potential options and tradeoffs, especially in the bridge pickup location. Most places I've seen recommend a neck pickup at around 5.8"-6.0" (~23.5% scale length), so I'm trusting that in general.
When I measure from the high-E bridge saddle to my Fender HSH strat's bridge pickup center line, I got 1.80" (7.06% scale length). The "Custom & Deluxe Bodies" PDF on Electric Herald has the bridge pickup at 1.60" (6.27% scale length) from the bridge. Looking around, it looks like a Les Paul Jr. has a slanted bridge so the high E is appr. 1.28" (5.2%) and low E is 1.60" (6.46%).
My tele has single-coils at 1.24" (high-E, 4.9%) and 2" (low-E, 7.8%), for reference, and a Donner thinline tele copy I have has the humbucker bridge at about 1.6" as well...
However, I'm curious because I've been talking with ChatGPT throughout this build and it has repeatedly suggested a bridge pickup at 3.1" (12%) because I'm using P-90s. Here is its response when I asked about the difference in spacing between its recommendation and the templates I see out there:
What do you all think? Is ChatGPT hitting close to home, or full of crap here? Will a 3" bridge balance the tone better, or lose too much shine? I chose P-90s because I want a new sound and I've heard people rave about them, so I want to amplify (pun intended) all their best sonic features, but I'm also a novice and have never played P-90s before to have any point of reference.
Also, does anyone have sound samples for bridge pickups that are 1.6" vs. 3" from the bridge? I have two preschoolers, so I don't have a ton of spare time to make a sled and do a bunch of temporary wiring to try it all out... but I'm wondering if that's my only real option in the end, otherwise I'll just drive myself crazy thinking I should have chosen the other route (pun intended).
Why Strat and HSH Guitars Have Closer Bridge Pickup Spacing
- Stratocaster Design Philosophy:
- Strat-style guitars typically have the bridge pickup positioned closer to the bridge saddles (~1.6–1.8 inches / ~40–46 mm) to capture a brighter, sharper tone.
- This design accentuates high frequencies, which helps the bridge pickup cut through in a mix and balances the darker tones of the neck and middle pickups.
- Humbucker Placement in HSH Guitars:
- On HSH guitars, the humbucker bridge pickup is often similarly close to the bridge saddles to maintain a bright, focused tone.
- Moving it further from the bridge might produce a warmer tone, but it could reduce the distinct "bite" associated with the bridge position.
- P90 Templates Are Versatile:
- P90s, especially in bridge positions, are designed to balance warmth and brightness. Many templates mimic Strat or Les Paul Junior designs where the bridge pickup is placed closer to the saddles.
Why My Recommendations Are Different
The recommended ~3-inch spacing comes from considerations of tonal balance, harmonic response, and string movement:
- String Vibration Amplitude:
- Closer to the bridge, string vibration is smaller, reducing the pickup's output and focusing on higher harmonics.
- Placing the pickup slightly further away (~3 inches) allows it to capture a fuller, more balanced tone without losing clarity.
- Classic Telecaster Bridge Pickup Position:
- Telecasters often have bridge pickups placed further from the saddles (~2.9–3.1 inches / ~74–79 mm).
- This spacing gives the Tele its signature twang while retaining a full-bodied tone.
- P90s and Warmth:
- P90s excel at producing warm, punchy tones. Placing them too close to the bridge can make them sound overly bright or thin, detracting from their versatility.
- Positioning the P90 around 2.8–3.0 inches captures a good balance of warmth and attack.
Tradeoffs to Consider
Bridge Pickup Closer to Saddles (~1.6–1.8") Bridge Pickup Further Away (~3") Brighter, more cutting tone Fuller, warmer tone More focused high harmonics Balanced harmonics Classic Strat/modern rock tone Classic Telecaster or jazzier tone Less string movement, lower output More string movement, higher output What Should You Do for Your Build?
The best position depends on your goals:
- If You Want Strat-Style Brightness:
- Use the 1.6–1.8-inch distance typical of Stratocasters and HSH guitars.
- Great for high-gain or cutting, lead-focused tones.
- If You Want a Fuller, Telecaster-Inspired Tone:
- Use the ~3-inch distance to emphasize warmth and dynamic response.
- Ideal for clean tones, Americana, or more balanced rock styles.
- For P90-Specific Use:
- Try a compromise distance around 2.5–2.8 inches (63–71 mm).
- This keeps some brightness while allowing the P90's natural warmth to shine through.
