P-90 circuit technical questions
Discussion in 'Just Pickups' started by Obsessed, Jan 1, 2021.
  1. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    So, I have determined that the volume pot is faulty on my very inexpensive Grote "Jazz" this morning, so I might as well upgrade to CTS pots. I am a noobie with P-90s, so I am seeking out recommendations for tone capacitor value and whether I should go to audio taper pots like I put in my Sheraton II? I love the sound as is and it has a green cap with "2A473J (or perhaps "I") if that helps. Since I have already had to replace the output jack with a Switchcraft, I might as well ask about P-90 replacements too. I play blues/blues rock through this hollowbody. Thanks for any and all help. IMG_4850.JPG
    zippofan, savofenno and KyAnne like this.
  2. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    500k volume, 250k tone, 50s wiring, audio taper. That has always been a winning combo for the low wind P90s I've played.
    Whats the resistance on the stock P90?
    savofenno, PigBoy and Obsessed like this.
  3. Wyzsard
    Wyzsard Friend of Leo's
    Falls City
    Why change what you love ?Replace the pots and rock on.
    DugT and wevard like this.
  4. Obsessed
    Montana
    Ahh, interesting. Both pots are 500K and the P-90 measures at 6.4. I did the 50s wiring on my Sheraton years ago with great success. I suppose I can just look up the 50s wiring diagram for just the two knob arrangement. Thank you so much for the ideas.
    wevard likes this.
  5. Obsessed
    Montana
    Well, that was my original thought too, but now that I am in the thick of things and all of these P-90 experienced people here, I thought I would take advantage of the knowledge base. Nevertheless, I really want to get it back quickly and was hoping it was just a crappy solder job, which BTW they look pretty crappy.
    Thanks though for keeping me anchored to the original intent.
    Wyzsard likes this.
  6. Tuxedo Poly
    Tuxedo Poly Friend of Leo's
    Merseyside UK
    The 2A 473J cap is 0.047uF 5% tolerance.
    Addnine and Obsessed like this.
  7. Dacious
    Dacious Poster Extraordinaire
    Godzone
    https://www.pinterest.com.au/pin/576038608565548880/
    Use the Les Paul Jnr 50s wiring. Tons of examples on the web.
    Zepfan and Obsessed like this.
  8. Obsessed
    Montana
    Thanks. I was hoping someone could confirm that. Since it appears that most of the electrical components are sketchy at best, I thought I would replace the cap too.
  9. Obsessed
    Montana
  10. Obsessed
    Montana
    Anymore input before I commit?
  11. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Two 500k pots are okay, if they turn smoothly. The cap is as bit high, I prefer .015 or . 010 with neck pickups. For the 50ies wiring you only have to swap one wire.
    Obsessed and Wally like this.
  12. Addnine
    Addnine Tele-Holic
    New England
    With P90's I like 500k/.022 for blues, a more penetrating sound, 500k/.047 for clean and jazz.
    Obsessed and radiocaster like this.
  13. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    I would recommend 500k audio pots and a .022uF cap.
    A 250k tone pot would also be ok, though I might go for no-load for added options.
    50s wiring has advantages and disadvantages, on my Les Paul I found I liked it on the neck pickup, but preferred modern wiring on the bridge pickup.
    dougstrum and Obsessed like this.
  14. wevard
    wevard TDPRI Member
    Switzerland
    If you’re planning on ordering two 500k pots and you have a digital multimeter, measure the resistance of the faulty volume pot and the new ones. Choose the replacement with the value closest to the original if you want the guitar to sound as close as possible to what you’re used to. Even 50kOhm can make a difference.
    jvin248 likes this.
  15. TimTam
    TimTam Tele-Holic
    Melbourne
    I have a Grote. FWIW its components are mostly fine. A cap is not a mechanical part. It either works or it doesn't. It either matches the capacitance value on the label (or is within the specified tolerance) or it doesn't. Plus the first half of the tone rolloff is all due to the tone pot; the cap only kicks in for the bottom half.
    Anyone who solders guitars for a living is highly unlikely to produce bad solder joints. It's a simple skill. By 100 guitars or so (less for many people), you're as good as anyone at it. ;)
    You say you "love the sound". Be glad that great sounding guitars/pickups are not necessarily expensive. So I'm not clear on why you want to mess with other components. If it were mine, I'd measure the pot that needs replacing and match it with one of similar measured resistance, as suggested above. And leave it at that.
    Obsessed and Addnine like this.
  16. Wallaby
    Wallaby Friend of Leo's
    Here
    I am probably the oddball in this thread, but I like 500k/500k "vintage" taper pots and a .015uf cap for a neck P90, modern wiring.
    Obsessed likes this.
  17. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    +1 measure kohms of the volume pot you have and match a replacement when reinstalling, if you like the tone now.
    I avoid all 50s wiring schemes because the volume and tone knobs interact ... like turning the tone knob drops the volume. Most of the fans of 50s wiring never touch their tone knob but I use it and found that odd interaction. So be cautious before implementing.
  18. beanluc
    beanluc Tele-Holic
    California Bay Area
    0K and ∞K replacements are pretty easy to come by, depending how it measures out :cool:
  19. Addnine
    Addnine Tele-Holic
    New England
    P90's are a very versatile pickup and can work differently but well with a wider range of cap/pot values than other kinds of p/u. I also find that the cheap ones sound very nearly as good as the premium ones. Alnico/ceramic: they don't really seem to care.
  20. AJBaker
    Switzerland
    You're right, and it comes down to whether you like that interaction. A cool effect is that you can 'hollow out' the sound by turning down volume and tone about halfway. The signal becomes much quieter and loses a lot of mids, but still sounds clear with some treble.
    I found this useful on a neck humbucker for cleaning up the signal without losing all clarity.
    On the bridge pickup, however, I found I couldn't properly dial out brightness, until I was way down on the tone knob (at which point it turns to mud).
