Oversized Amp knob Trick
Discussion in 'Amp Central Station' started by Intubator, Jan 6, 2021.
  1. Intubator
    Intubator Tele-Holic
    Bawlmer, MD- Home of the "Mayor Shuffle"...
    I just built this amp and when I got to the point of putting on the control knobs I realized that the pot shaft diameter and knob diameter were mismatched to the point that with the knob set screw tightened, turning the pot shaft made the knob rotate in a very noticeable eccentric offset motion. Here's my solution to share with folks who may have run into a similar situation by making a fix with a plastic drinking straw, and it perfectly centers the oversized knobs snugly on the shaft and gave it a little extra grip and the set screw some extra "bite".
    These were Alpha pots and the straw had to be gradually pushed onto the shaft, it is a snug fit.
  2. strat a various
    Good idea.
    I've been using heat-shrink for that.
    theprofessor, Wally and Intubator like this.
  3. J-Flanders
    J-Flanders Tele-Meister
    Flanders
  4. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    +1 on the heat-shrink, especially if you can find the stuff that has teflon in it (I think).
  5. schmee
    schmee Doctor of Teleocity
    Do those knobs have a brass liner or just plastic? I think the brass lined ones are much better, and the plastic ones strip out the set screw super easy. (dont ask how I know!)
    But either way, I use CTS pots and dont have that fit problem at all... Use some Alpha's in certain positions too...? Is that a metric pot or something?
    brookdalebill likes this.
  6. Intubator
    Yes these are brass lined knobs from AE supply. Don't think they are metric pots, but the knobs may be... IDK. Either way the straw seems to be a perfect adapter, the knobs are very snug and the spacing is uniform.
  7. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    You can get Alpha pots with either metric 6mm shafts or standard 1/4" (6.3mm) shafts. You're putting standard knobs on metric shafts. As long as the fix works, I'd say you're OK.
    Al
    Si G X likes this.
  8. StevesBoogie
    StevesBoogie Tele-Afflicted Ad Free Member
    North Carolina
    I saw this trick once in an episode of MacGyver!
    Intubator, theprofessor and foundjoe like this.
  9. craigs63
    craigs63 Tele-Holic
    Naperville, IL
    What color straw has the best tone, or does it depend on if it's a bass vs. treble control?
  10. foundjoe
    foundjoe Tele-Holic
    Kansas
    And you’re keeping the oceans cleaner and saving fish.
  11. Mark the Moose
    Mark the Moose Tele-Afflicted
    Colorado Front Range
    I think that makes it louder...
  12. brookdalebill
    Austin, Tx
    Brilliant cheap fix!
    I’m a big fan of Fender “cupcake” knobs.
    I have them on one of my amps, and four of my guitars.
    They’re lightweight, and it’s easy to see where they’re set.
    I only recently became aware that some cupcakes have metal inserts, and some don’t.
    Now when I go to guitar shops, I always see if they have the ones with the inserts.
    I ordered a good supply of the brass insert/sleeves from AllParts.
    The OP’s solution is brilliant.
    Intubator likes this.
