Overdrive for Vox AC15
Discussion in 'The Stomp Box' started by TeleBrew, Oct 20, 2018.
  1. Chuckster
    Chuckster Tele-Holic
    Boston/Cape Cod
    I scored an MXR Wylde Overdrive as a toss-in on a guitar purchase recently.
    In short, don't rush out to buy one. I have tried nearly every combination of settings and guitars and I am underwhelmed.
  2. TeleBrew
    TeleBrew Doctor of Teleocity Ad Free Member
    Evergreen, Colorado
    Good question. We're doing originals in my band, with a few covers sprinkled in. The originals cover a lot of musical territory, with Americana, rock, and alternative-type of guitar tones being necessary on any given song. I use my Rick 330 through the Vox most of the time. (I tend to play my Tele and Jazzmaster through my Hot Rod Deville more than the Vox, fwiw).
  3. heltershelton
    heltershelton Tele-Afflicted
    not houston
    check out the seymour duncan 805.....covers alot of ground.
    TeleBrew likes this.
  4. Lord_Ingipz
    Lord_Ingipz Tele-Meister
    Cicero, IL
    Had the original bullseye model. Terrible od.
    Chuckster likes this.
  5. EnzoDooder
    EnzoDooder TDPRI Member
    Kansas
    I personally advise against this although it always boils down to personal taste. Mid-heavy tube screamers play well with scooped Fender style amps but Vox's are already mid heavy so tubescreamers can easily tend to be too much with that combination.
    Of course there are always exceptions but generally speaking, overdrives with a flatter EQ response are going to yield more usable results with Vox amplifiers.
    MadJack, blakestree and heltershelton like this.
  6. ellisvertellis
    ellisvertellis Tele-Holic
    belgium
    Ik feel the same way. Tried a classic TS and it's not what the Vox needs IMO. I like a pedal that clips hard and gets a bit fizzy: that fizz just blends with the voxes top end...
  7. stnmtthw
    stnmtthw Friend of Leo's
    New Mexico
    I just use a regular old Boss SD-1 with mine.
  8. Mincer
    Mincer Tele-Holic
    Tampa Bay Area
    While most TS-type pedals I wouldn't recommend with a Vox, the 805 does have the 3 band active EQ so it doesn't have to suck out the bass and boost the mids as much as most TS pedals.
    heltershelton likes this.
  9. El Marin
    El Marin Tele-Afflicted
    Madrid, Spain, EU
    YEs, it's all about to taste... and moving tone pot on your amp and pedal untill you find what you like
    I love it
  10. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    I thought the ac15 has a master/channel volume controls?
    have you tried to eek the dirt out of the amp with your guitars volume knob?
    I was under the impression one of the ac-15's strengths was the tube saturation. (I don't have any experiecne with the model, though I've always wanted to play one).
    MadJack and AAT65 like this.
  11. TeleBrew
    Evergreen, Colorado
    Oh, I use the dirt on the amp for sure, which sounds great, but it's not a channel-switchable amp so it's nice to have a dirt pedal to click on when I have it set clean. I often play clean in my band, but then need dirt for parts of songs or solos.
    MadJack likes this.
  12. fasteddie42
    Tip of the Mitt
    A/B/Y box might be cool?
    Set normal to clean, switch to a dirty top boost?
    Again, I don't have first hand experience with the model. I just watched the linked episode of "that pedal show" on the the topic, lots of good info to work with.
    MadJack, AAT65 and TeleBrew like this.
  13. TeleBrew
    Evergreen, Colorado
    That's a good idea, and one that I flirted with when I first got the amp, but to be honest the normal channel doesn't do anything for me. It's all about that Top Boost sparkle (and growl)!
  14. 3-Chord-Genius
    Winchester, VA
    Joyo Ultimate Drive. That's what I used and it was perfect with that amp.
    Il Belva likes this.
  15. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    Hot Cake is the best, but if you don't want to spend that much...Rat. They both sound great with my AC-15.
    bendercaster and TeleBrew like this.
  16. blakestree
    blakestree Tele-Meister
    Savannah, GA USA
    Yep, Crowther Hotcake.
    RetroTeleRod likes this.
  17. fatcat
    fatcat Friend of Leo's
    Very Deep South
    I'm currently using a combination of Plimsoul and Wampler euphoria drive.
    Normal channel; master volume at noon or better.
  18. fatcat
    Very Deep South
    Im glad you posted this.
    deadbeat son likes this.
  19. TokyoPortrait
    TokyoPortrait Tele-Afflicted
    Tokyo, Japan
    Which channel are you wanting this for? I'm presuming the Top Boost.
    https://reverb.com/news/five-overdrives-for-your-top-boost-vox.
    Of these, closest I have is a Timmy clone. It's pretty good actually (whatever that means), if you take the time to dial it in - seems to be a bit of a moving target some days.
    As an aside, I use my cheap tremolo (Donner Golden Tremolo) as an always on wee kick. Set to low amounts of wobble, it drives a little to compensate for the attenuation, and sounds really nice (to me).
    Edit: this is into my Top Boost only AC4HW1.
    Pax/
    Dean
  20. Marc Morfei
    Marc Morfei Tele-Afflicted
    Philadelphia, PA
    I have an AC15 as my main amp (stock greenback speaker), and use a strat. I only use the Top Boost channel, with the tone cut pretty far down, like 9:00. I don't want to dial out the sparkle. I have a bunch of OD pedals:
    Timmy is really good. Transparent, Lots of sweep on the gain.
    Xotic EP Booster is GREAT. I mean really great with the AC15. It is a clean and dark boost which rounds out the tone perfectly for leads, etc. It doesn't color the tone, it just sort of richens it, without adding distortion.
    I have two Boss pedals that both sound fine. The Blues Driver sounds good with any amp. Surprisingly (to me anyway), for a very inexpensive pedal the Boss OD-3 sounds GREAT with the Vox. Adds just the right type of chunkiness. I got mine used for about $40 I think.
    The one pedal that does NOT sound good with the Vox, IMO, is the Tube Screamer. I dunno why. It just sounds kind of blah to me. When I had a Blues Jr that pedal sounded great.
    Actually I just ordered a Barber GainChanger and RAT used on reverb. So the TS9 will come off, and one of those will go on in its place.
    Everyone always recommends a Hotcake, but good luck finding one used. I refuse to spend $200 on a pedal (at least until my playing improves enough to deserve it).
    But I cannot say enough about the Xotic EP Booster. It's perfect.
