Overdrive/Distortion + Built-in Boost suggestions
Discussion in 'The Stomp Box' started by dreamingtele, Oct 9, 2019.
  1. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    Hi all,
    I play in church, mostly light gain/drive.. but my preference is a bit heavier bluesy kind of drive, so I set my drive tones a hair dirtier than usual.. I like it that way..
    Here's my set up.. Even though we have an amp at the main stage, there are times I play in a different venue that has a different amp, or sometimes we go straight to PA.. to be more consistent, I set whatever amp I use to flat EQ and I have a Joyo American Sound (now replaced by Tech21 Blondie), as a clean base tone, also "always on" and I use two gain stages.. stage 1 - klone-type "always on" pedal, stage 2 - heavier gain for solos/lead lines.. which is the Lovepedal AMP11.. I play Tele's.. one is AVRI62 all stock, and one Fender Japan 62ri with AV64 pickups..
    I like how it sounds, but recently I feel like my taste is changing and I no longer find the Lovepedal AMP11 suits my taste.. I like a pedal with the boost function because sometimes when the house and the all of the band gets pumped, I need to step up.. so its functioning more like a volume boost adding a bit of dirt..
    Before I get roasted, I know tones are all subjective, I'm mainly looking for a pedal that has built-in boost to try something different.. and what are you guys using? what have I been missing?
  2. Guitarteach
    I have a Fulltone Fulldrive 3 that has a boost and a gain stage and you can flip the order to get a volume boost or get more dirt.
    It’s much better driving an on the edge amp rather than into something super clean though like most ods. The Comp Cut mode is better.
    My preference (and what has stayed on my rig) is a standalone MXR Microamp.. I can put it anywhere to push a pedal for more dirt or after for a level boost.
    Today I’d get two pedals and enjoy the flexibility. TC Spark Booster into something else.
    LooseJack likes this.
  3. dreamingtele
    What? They made a v3 on this?? I didnt know! Im gonna head to youtube and check it out..
    I wanted a Tim in the first place, but I couldnt find it, and when I found one, seller was asking ridiculously high price for one.. given its no longer in production, and quite rare, but my choices were LovePedal Amp11 and Fulldrive 2-Mosfet.. the LovePedal won because of my limited real estate on my board.. but I can shift things around as Im also thinking about replacing the klon with something with a bit more character..
  4. Bristlehound
    Bristlehound Friend of Leo's
    Wales
    The Caline Crazy Cacti is a Fulldrive FD2 clone for a lot less money. Might be worth a try.
    dreamingtele and leonard d rock like this.
  5. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    Boost after dirt for more volume.
    dreamingtele likes this.
  6. JBFatFingers
    JBFatFingers Tele-Meister
    Canton, MI
    To stay on the Fulltone topic, I have the Fulldrive 2 v2 and it's great - has a separate volume knob for the boost mode to make it easier to dial in how much of a kick you get.
  7. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    I honestly don't love any of the boost and od 2 in 1 pedals enough to recommend one and every time I think about building one myself I talk myself out of it. I'd rather have the flexibility of having two pedals
    Chiogtr4x and D_Malone like this.
  8. D_Malone
    D_Malone Tele-Meister
    Ferndale, MI
    Same here, but I have high hopes for the soon-to-be-released Boss OD-200. I’ve pre-ordered one. Fingers crossed.
  9. Chief101
    Chief101 Tele-Meister
    Not far from Nashville
    Versatile pedal. Hope you find “the one”.
    lineboat likes this.
  10. dreamingtele
    i love Caline pedals! I can certainly try and the smaller footprint appeals to me!
    there are fd2 versions within my area in the classifieds, i can check them out first before buying them
  11. dreamingtele
    really intrigued with this pedal! Im just looking for a store that stocks this near my area so i can demo it
  12. dreamingtele
    the only reason is because I have limited real estate on my board lol.
    I can shift things around, its bound to be re-wired anyway. But for now, Im just really into 2-pedals-in-1.
  13. black_doug
    black_doug Friend of Leo's
    Toronto, Ontario, Canada
    I like this one.
  14. 63 vibroverb
    63 vibroverb Tele-Afflicted
    Lititz, PA
    A lot of guys do the 4-way switch mod to their Teles to have a “boost mode” at their fingertips. I know I personally like having it in my Teles. Sounds like you step on a boost pedal.
    Pedal wise, for a tele, sometimes I’ll dust off the old Sunlion if I wanna get really gnarly and explosive - germanium fuzz face and a rangemaster boost in one. For something a little more tame, the BMF Marc F’n Ford pedal or The Godfather II would be great, I bet. Whatever kinda boost you get, I think the germanium rangemaster/treble booster type is key to really pushing it over the edge and cut thru the chaos.
  15. Jakeboy
    Jakeboy Tele-Afflicted
    Sedalia, MO
    2 suggestions:
    1. Check out other Lovepedals. The Box of Awesome comes to mind as does the COT/Eternity....he specializes it seems in first with boost.
    2. Ask Mike at Chicago Stompworks to make you a BloozeBoost.it is a Bluesbreaker on one side and a Red Llama on the other. Stackable...and cheap.
    oh, and plus 1 on the series position 4 mod for your tele.
    RYAN1987M and El Tele Lobo like this.
  16. dreamingtele
    I havent had any experience with a treble booster type OD/boost.. I dont want to cut heads, but just something closer to edge and a boost to top it all off, but independent so that I can use the boost if I dont want to hit the second stage OD...
    The klone I have is my first stage gain and always on.. if I hit the boost, it makes me a bit louder, and giving it a bit of dirt, only a little bit.. then if I want something really dirty, I'll hit the second stage dirt.. and when everyones in the clouds and the band is really pumped, I'll hit the boost again to send the tele to the top.. I wont have a problem cutting through I think, those 60's teles I have are bright enough on their own..
  17. KC
    KC Friend of Leo's
    Missoula, Montana
    If you can find a tchula check it out — small footprint, variable boost, match made in heaven with a tele
  18. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Rumor has it this is based on a tubescreamer into an OCD. The order is reversible.
  19. Blue Bill
    Blue Bill Poster Extraordinaire
    They're popular for a reason:
    leonard d rock and dreamingtele like this.
  20. 63 vibroverb
    Lititz, PA
    What you’re describing is basically what the BMF Marc Ford and Godfather II pedals are designed to do. They’re dual pedals with independent switches for overdrive and boost. The name “treble booster” is a bit misleading and isn’t really what it sounds like. What it really does is tightens the bass and boosts the upper mids to sound more focused and make notes sing. Think Brian May solos. They’re designed to work together with cranked amps or other dirt pedals.
