Output Transformer Wiring Question
Discussion in 'Shock Brother's DIY Amps' started by TobyZ28, Jan 28, 2020.
  1. TobyZ28
    TobyZ28 Tele-Meister
    Vancouver
    Hi all, I have a yellow wire coming out of the output transformer (along with the green and black wires). Is this a centre tap? What is the best thing to do with it as I have no reference to it in my schematic (Cover the end up with ShinkWrap/other)?
    The schematic I "thought" was for the output transformer only shows a black and green wire coming out as well, no yellow.
    Thanks in Advance...
  2. schmee
    It's likely a multi tap tranny. What brand?
  3. Lowerleftcoast
    Lowerleftcoast Tele-Meister
    california
    If there is no data on the OT. I have a NIB multi tap 18watt 4,8,16 ohm. If you want to take resistance readings green to black and yel to blk, we can compare. Maybe you can figure what ohm speaker works with the green/blk and yellow/blk.
  4. Lowerleftcoast
    california
    Assuming it is a multi-tap OT, I would wire it like a hot rod deluxe. Or similar.
  5. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Those colors are generally associated with the OT secondary which connects to the speaker. As the fellas pointed out, a few resistance readings will help to determine which tap is which. The black is most likely the common which goes to the sleeve of the output jack.
    The OT primary should also be three wires. One goes to B+ and the other two go to each 6v6. A resistance reading will also help determine which ones to use there.
  6. schmee
    "(Cover the end up with ShinkWrap/other)?" ....short answer, yes, cover up the end of the tap you are not using.
  7. TobyZ28
    Vancouver
    The ohms on the OT input side are:
    • Brown-Blue 538 Ohms
    • Red - Blue - 274
    • Red - Brown - 264
    The output side was bouncing around 0.1 and 0.0 for all three combinations, I don't think my Klein multimeter goes any lower. I do have a low current 120-20v AC transformer I can wire up. Would it make sense to wire this up to the Brown/Blue wires and measure the voltages between the Green/Black/Yellow output wires or will this roast the transformer :D?
  8. TobyZ28
    Vancouver
    I went ahead and did the test. Step in if i'm mathing it wrong, this is a total noob amp math attempt!
    Input Voltage to Brown/Blue leads: 19.4V (RMS)
    Output Voltage:
    • Blue/Green - 0.72V
    • Yellow/Blue - 0.5
    • Yellow/Green - 0.21
    Overall Step Down Multiplier:
    19.4/0.72 = 26.66x
    So say I have 350VAC going in through the Brown and Blue leads...
    350V/26.66 = 13.12 VAC out (?)
    I have no clue how this translates into what kind of speaker to hook up or what the yellow wire is for :D.
  9. Lowerleftcoast
    california
    Blue/Green - 0.72V = 8ohm
    Yellow/Blue - 0.5 = 4ohm
    Some options:
    Shrink wrap yellow
    Wire in a switch for 8ohm and 4ohm selection
    Buy a switching jack and wire it like a hot rod deluxe
    If you will not be running an extension speaker, just shrink wrap the yellow. Leave it long. It can be used for negative feedback at a later time, if so desired.
  10. TobyZ28
    Vancouver
    Perfect, will do!
