output transformer info needed ....... (Or not)
24 track
kamloops bc
does any one know of a direct replacement output transformer for a 68' custom princeton reverb RI that has an 8 ohm and a 16 ohm secondary the stock unit is a fender P/N 0069362000 ( 8 ohm out) , this customer wants to convert this amp ( for some ungodly reason) to drive a 4 X12 Cab, I restored his amp back to factory specs after he butchered the mod with an 8 ohm ceramic resisitor DPDT switch ( cold soldered connections , shorting to ground all sorts of nastiness ) not pleasant .
I did not know of one right off that would be small enough for that amp,
any sugeations other than "forget about it", would be appreciated , and hey if aome one else has done this mod,
A) how well did it work ?
B) what were any issues ?
C) what did you use?
thanks .....24
Dacious
Godzone
Never used one, but Hammond is the go-to for many people. This is what they list for a PR.
24 track
kamloops bc
thank you , I fired them off a question , I will post the answer ,thank you again!
