Outer Foil Side on Emerson Cap?
Discussion in 'Tele-Technical' started by Beebe, Jun 15, 2021.
  1. Beebe
    Beebe Tele-Meister
    Atlanta
    Anyone know what side is the outer foil on an Emerson Cap? I can't find a ring marking it on this one. IMG_20210615_083525849.jpg
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I do not know. But if it mattered, it would be marked. With low-voltage caps on guitars, it won't matter. I would solder it in so it looks nice and still easily read the values.
    IamBlue and NoTeleBob like this.
  3. Beebe
    Beebe Tele-Meister
    Atlanta
    That's pretty much what I decided. I assumed the right side when reading the text was the outer foil. Though it does make sense to me that the outer foil going to ground could provide a little bit better noise rejection, as well as the psychoacoustic effects of knowing it's in the "right" way. But I'll be objective this time and use my ears. I watched a you tube video that demonstrated that the markings arent always correct anyway. Made me want to get an o-scope so I can test and mark all of mine.
  4. IamBlue
    IamBlue Tele-Meister
    South Carolina
    As stated above it doesnt matter in guitar circuits.
  5. El Marin
    El Marin Friend of Leo's
    Spaniard in Pärnu, Estonia, EU
    I cannot hear a difference, but now you ask... Usually the thickest end is the outer foil.
    If you can see, the LEFT side is different and thicker than the right side. The thicker one is what is used to fill it with oil. That is the outer foil.
    A friend of mine, electronic and a freak of sound and condensers, and friend over all says and swears that it makes less noise if solded propperly. He even demostrates it with an oscilloscope.
    He has a page talking about it. Sorry, is in Spanish
    http://www.pisotones.com/Articulos/DirCaps/DirCaps.htm
    Boreas likes this.
  6. Boreas
    Do an experiment for us and try it both ways. Report back if you can tell the difference!
  7. Beebe
    Beebe Tele-Meister
    Atlanta
    Probably a good idea. More likely I'll see how it behaves and flip it if there is anything I'm not liking about the tone control or noise level.
  8. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    You might email them and ask,just a thought.:)
  9. corliss1
    Lansing, MI
    Unless you start getting into high frequency radio things, it doesn't matter.
    Peegoo likes this.
  10. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    A 2-cent ceramic cap performs just as well in these ultra-low-voltage AC applications, and leaves way more dollars in your wallet.
    Boreas and Rowdyman like this.
  11. Boreas
    And more room in the control cavity.
  12. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    Exactly!! Yes, the Emerson caps looks sooo cool, but what really matters is actual measured capacitance value.
    FWIW this cap is simply shunting to ground; IMHO outer foil orientation is a moot point in a guitar context.
