Other options for splitting guitar/harp to two amps?
Discussion in 'Bad Dog Cafe' started by Lone_Poor_Boy, Sep 27, 2021.
  1. Lone_Poor_Boy
    Lone_Poor_Boy Tele-Holic
    Colorado
    For my guitar I typically use my Boss TU-2 tuner to send to two amps as it is last in the chain of the few pedals I use. It has two outs; one goes silent when you engage the pedal and the other does not. It has worked very well, but I want to setup my harp to go to two amps as well and it got me curious as to other options. Smallest footprint etc., that does not hurt the signal.
    I also use a Radial Pro DI Direct Box for a lot of different 2-to-1 or 1-to-2 functions and if there is something smaller and cheaper that works, I'd rather not tie it up.
  2. mad dog
    mad dog Friend of Leo's
    Montclair, NJ
    Radial Twin Cities. Isolated power, phase switch. It's a big step up from passive splitters. No noise, no problems ever.
    Lone_Poor_Boy likes this.
  3. Fiesta Red
    Fiesta Red Poster Extraordinaire
    Morley ABY worked for me for many years.
    Buckaroo65 and Lone_Poor_Boy like this.
  4. teleman1
    teleman1 Friend of Leo's
    Arizona
    Ever think of having a bass amp for the 2nd amp? Low end fidelity is joyous.
  5. schmee
    A Y cable would work, but with anything other than a special device (like one of the Radial devices) you will have signal loss compared with no splitter. It may not matter as you can just turn up.
    Do you want to go to both amps all the time? Then just have one output and jump the amps together.
    Lone_Poor_Boy and Willie Johnson like this.
  6. 3fngrs
    3fngrs Friend of Leo's
    Ohio
    I use an Earthquaker SwissThings but that may be a little sophisticated, not to mention expensive, for your needs.
  7. nedorama
    nedorama Tele-Holic
    Radial Bigshot ABY - it's the less expensive passive version of the Radial Twin cities mentioned above. I use it to split between my Princeton Reverb and a Dr. Z MAZ 18 - either one, or usually both...
  8. Lone_Poor_Boy
    Colorado
    I'll have to try that, just because, as I have an Ampeg Rocket B-100R.
  9. Lone_Poor_Boy
    Colorado
    Thanks all. Good to see some solid options in the $100 range.
