OT that will handle 2x6v6 or 2x6l6's?
Discussion in 'Shock Brother's DIY Amps' started by bobbyk, Jul 27, 2011.
  1. bobbyk
    bobbyk TDPRI Member
    Connecticut
    I'm looking for an OT that can be used in an amp designed to accept either 2x6v6's or 2x6l6's into an 8 ohm speaker. Is it available off the shelf? Do you think it can be custom made?
    Thanks.
  2. tubeswell
    tubeswell Friend of Leo's
    NZ
    Something with about 25-30W power rating and 5k - 6K6 Pr Z (if you want to keep it simple), or a 30W with 4k Pr z and 4, 8 and 16R secondaries (if you want to get fancier with the load resistances). JM2CW
  3. sjhusting
    sjhusting Tele-Afflicted
    Germany
    Mercury Magnetics makes the FTDO-59M, with 5K6 and 8K taps.
    Or you could accept 4K for the 6L6s, and use a normal-priced Hammond with multiple taps, and just use the correct other tap for the 6V6s.
    for 6L6: 4K/8 = 500/1 ratio
    4K/4 = 1000/1 ratio
    so the 4ohm tap would give you 8K with 8 ohms, which would work for 6V6s.
    steven
