I'm working on a clone of an amp design (Ampeg R-12-R Reverberocket) that has a push-pull OT specified as 10k Ω primary (300 Ω DCR), 8 Ω secondary (0.7 Ω DCR). It's a 2 x 6V6 amp with a paraphase PI, so the OT was probably rated at 15 W or so.
I bought a ClassicTone OT (40-18037 intended as repl. for Marshall 18 W) with similar impedance specs: 9.2k Ω primary and multiple outputs at 4, 8, 16 Ω. It's a fairly substantial one weighing 2#-3oz or 0.98 kg with mount spacing 3-9/16" -- a slightly bigger stance than a Fender 125A1A, for instance.
Now here's my concern: the DCR measured for the primary on the ClassicTone is 640 Ω end to end of the primary (310 and 330 per side) -- over twice what the spec by Ampeg is. The secondary DCRs for the 3 taps are all in the same order of magnitude as suggested by Ampeg, 0.4 to 0.7 Ω (though measuring single-digit ohms is very unreliable given the multimeter I have).
EDIT: in case anyone was going to ask -- No, I don't know what the spec or actual inductance is for either of these, nor their turns ratios. I suppose with a low-voltage setup I could establish the latter for the one I have in hand; but I haven't yet.
If I compare the specs of various similar Hammond offerings having roughly the same primary impedance, I find the following:
1760E (15 W, repl. for Fender 5E3 Deluxe, 8.5k primary): about 310 Ω end-to-end
1760H (20 W, repl. for Fender AB763 Deluxe Reverb, 6.6k primary): about 350 Ω end-to-end
1750PA (18 W, repl. for Marshall 18 W, 8.4k primary): about 635 Ω end-to-end
So, it doesn't seem to be a fluke that the Marshall OT does have a higher primary DCR than comparable Fender OTs.
Is that difference in primary DCR spec a problem? If the Ampeg spec is indeed end-to-end and the two OTs really have a double/half relationship in their primary DCRs, then what would that difference result in, in terms of the change in OT performance?
Should I be looking for an OT with 8.5k to 10k primary impedance and a lower primary DCR? I imagine I could sell the (now unobtanium) ClassicTone for what I paid easily enough. But I haven't found a better match, except for the "original" replacement OT-149 (by Heyboer) from Fliptops.net, who don't seem to be very forthcoming about specs, and have a pretty steep price compared to the ClassicTone.
