OT location
Discussion in 'Shock Brother's DIY Amps' started by RollingBender, Jun 19, 2020.
  1. RollingBender
    RollingBender Tele-Afflicted Vendor Member
    SW Minnesota
    Are there any special considerations when laying out an amp with the PT at one end of the chassis and the OT at the other end? ...something like this....
    ...only with the tubes standing up in between the transformers.
    Any special lead dress or routing that needs to be observed?
  2. King Fan
    Salt Lake City
    The important thing is to isolate the tubes in a perf-steel cage... and mount a slab of Lucite -- lit from below -- halfway between the transformers. :)
    telemnemonics, tubegeek and awasson like this.
  3. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    I have considered that configuration. However the op transformer is a ways away from the power tubes which it is connected to. Other that that it is great, moving the power tubers closer puts the preamp tubes closer to the power transformer. So I end up with the op transformer between the power tubes and preamp tubes. Which is still a ways away from the power transformer
    When I looked closer you have the preamp tubes closest to the power transformer which I tend to avoid. This sort of thing is always a balancing of compromises.
  4. RollingBender
    SW Minnesota
    Ha! That’s the example I’m going for. Designing a cabinetless head with cages around the tubes but in “normal” configuration, I end up with 2 cages.
    As far as the Lucite...I’ll have to add that to the design.
    So...what did Ampeg do to address this issue? Can’t find a decent gut shot of a Portaflex.
    King Fan and tubegeek like this.
  5. RollingBender
    SW Minnesota
    Did some more searching on the google for Portaflex gut shots. All the photos that I found, the board is covering what I want to see and/or the resolution is not good enough to confirm what is going on but it looks like they just twist the primary leads from the OT to B+ and run the secondaries you the output jack with no concerns.
  6. telemnemonics
    Is there a reason you want the OT far away from the power tubes?
  7. RollingBender
    SW Minnesota
    Having the PT and OT at opposite ends would simplify the fabrication of the mesh cage. The way I’m going to build this one, the tubes will be running down the middle of the chassis rather than along the back (point-to-point-ish).
  8. elpico
    elpico Tele-Afflicted
    Vancouver BC
    See also:
  9. schmee
    schmee Doctor of Teleocity
    Your setup looks fine. I have found in my experimenting it seldom makes any difference as far as noise goes. Twist the long wire runs though.
  10. RollingBender
    SW Minnesota
    Here’s a gut shot of the amp @elpico posted...
    Looks like the OT leads just lay tight and flat to the chassis.
    Looks like I may be revising my layout after all. The Hiwatt example is not too far of a departure from my build plan.
    tubegeek likes this.
