Hi, this is related to the current guitar I've almost finished:
www.tdpri.com
That other post details the overall wiring in the guitar. This post is specifically related to the 3 way on-off-on mini toggle switch I'll be using as a tone circuit for the middle single coil pickup in that guitar.
Basically the middle pup's tone will have 3 switchable values via the 3 way switch. middle 'off' position will bypass any tone control and therefore be the brightest sound. The other two of the three positions on the switch will be equivalent to ~8 and ~4 respectively out of 10 on a typical tone control.
As far as I've gathered from the helpful folk here on tdpri, I need to use a capacitor and resistor combination wired to the switch to mimic what a typical tone pot would do.
In order to find out what resistor values I would use with the switch, I plugged in my strat, played both neck and bridge pups (the ones that are wired to tone pots on my strat) and chose two sounds I found the most useful for me, which are about 8 and 4, so slightly less that full tone and a hair under half full tone.
I then took off the pickguard and measured with my multimeter (on the two tone pots) what the resistance was for each of these two values (tone at 8 & tone at 4). Cap value for both tone pots was .022
These are the results I got:
Neck pup tone @ 8 = 123 Kohms. Neck pup tone @ 4 = 14 Kohms. (Neck pup tone @ 10 = 260 Kohms)
Bridge pup tone @ 8 = 110 Kohms. Bridge pup tone @ 4 = 13 Kohms. (Bridge pup tone @ 10 = 234 Kohms)
I was surprised at these results. In my inexperienced view, I just presumed that tone at 8 would be much closer to 250 Kohms. Was surprised to see it at just under half of the 250K pot value. And to see the resistance to be just under 15 kohms when tone pot at 4 was a real surprise.
Anyway, I'm sure there's goods scientific reasons for these results, but now I just want to be sure about choosing the correct two resistors for the 3 way toggle (tone) switch.
Do I go by my multimeter results and go with a ~120 Kohms resistor to achieve a tone pot turned up to 8 sound?
and similarly go with a ~15 Kohms resistor to try achieve a sound similar to a tone pot turned up to 4?
Need some advice/help on wiring this up (5 way import style blade switch)
This post is directly related to this one: https://www.tdpri.com/threads/is-it-possible-to-change-a-pickups-tone-via-a-3-way-mini-toggle-switch-and-no-tone-pot-or-some-other-way-with-no-tone-pot.1107433/ I'm using an import style 5 way blade switch, due to the standard 5 way switch being too...
