One of those days
Discussion in 'Burnt Fingers DIY Effects' started by pi, Sep 13, 2020.
  1. pi
    pi Tele-Meister
    bay area, CA
    Just finished up a build (Rog Azabache). Played it with the enclosure opened, and verified it worked.
    Squeezed the board into its tight space, boxed it up, no sound... something shorted.
    Since then I've been checking everything 2x and 3x. Checking every trace, every component. Tidying up solder, making so no runs or shorts are on the veroboard. Swapping transistors, etc.
    After every time I think I find the issue, I plug it and, and nothing....
    until I just realized on my practice amp I've been putting the input jack into the output and vice versa. I have wasted hours. I probably did this 10x times or more before I bothered to check my jacks.
    The cable with a fat jack is on the amp side and one with thin one was on the guitar side. For some reason I had it my mind I had connected the the fat jack to the guitar but never even bothered to look. Sigh.
    thanks for letting me vent.
    Iago, WalthamMoosical, jscud and 3 others like this.
  2. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    BTDT.
    At least you found the issue - I've wasted hours and still gotten nowhere!
    zippofan likes this.
  3. zippofan
    zippofan Tele-Afflicted
    Pennsylvania
    Yep me too!
  4. ponce
    ponce Tele-Afflicted
    Croatia
    Been there a few times:D
    pi likes this.
  5. jscud
    jscud TDPRI Member
    Silicon Valley
    I'm in the same situation right now! Took a break to avoid getting over-steamed. Now, where did I put my screwdriver.
    pi likes this.
  6. getbent
    getbent Telefied Silver Supporter
    San Benito County, California
    22 out of 7 times, the problem is in the physical layer. glad you got'er fixed up.
    pi likes this.
  7. pi
    pi Tele-Meister
    bay area, CA
    I just want to finish up now, and I dropped 3 of the 4 enclosure screws in the shag carpet. Found 2 of them. The other seems to have vanished to a parallel universe. That last missing screw is going to haunt me.
    tubegeek and getbent like this.
  8. getbent
    maybe a magnet will be yo frien.
    tubegeek likes this.
  9. tubegeek
    Brooklyn, NY
    BTDT #2.
    pi likes this.
  10. 39martind18
    39martind18 Friend of Leo's
    Spring TX
    Until you step on it!
  11. Lonn
    Lonn Friend of Leo's
    Indiana
    Had a similar experience last night putting a Tele back together after a refinish. Whoever wired this thing up was nuts. I can't for the life of me get the middle position to work as wired so I'm going to ditch the current pots and switch and redo it myself next week. Tele wiring is not rocket science.
    Jlwctn likes this.
  12. Gunny
    Gunny Tele-Holic
    Newcastle, Ontario Canada, near Toronto
    Pi: I've repaired and modified many tube amps. When it came time to put it all together and test - no sound. I forgot to put the tubes in! Didn't take very long to figure out but I admit that's happened more than once. I was thinking so much about what was worked on that I forget the basics.
