One of one of those Qs? EL34BHT 6CA7
Discussion in 'Glowing Bottle Tube Amp Forum' started by fyshnutz2, Feb 24, 2021.
  1. fyshnutz2
    fyshnutz2 Tele-Meister
    Boston North Shore
    Hello, I have a set of EL34BHT 6CA7 tubes hanging around and I don't even know what these belong in (or for that matter why I purchased them years ago, senility? )
    So what are EL34BHT 6CA7 used for? I have an AC15 and Princeton Reverb and it's not them.
    Thanks in advance - Eric
  2. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Mmm...toss them in a Marshall.
    Cali Dude likes this.
  3. kbold
    kbold Friend of Leo's
    EL34BHT (AFAIK) are an unsuccessful attempt to meet the higher voltage spec's of old EL34's.
    EL34BHT seem to have max plate voltage of 600V. Old EL34's were 800V
    Wouldn't use them on a Dynacord Eminent amp, with over 750V plate Voltage.
    OK for anything EL34 below 600V.
    fyshnutz2 likes this.
  4. NTC
    NTC Tele-Holic
    Are they large bottles or thin bottles? Thin is typical of EL34'S. Large fat battles are 6CA7's. Both types bias the same and are considered interchangeable, but the have different sound characteristics.
  5. fyshnutz2
    Boston North Shore
    Thanks for the info, I have since found this cut to the chase description "The EL34 is found in many British guitar amps and is associated with the "British tone" (Vox, Marshall, Hiwatt, Orange) as compared to the 6L6 which is generally associated with the "American tone"", - close enough.
    The tubes are pictured below. It appears as though I could of used these in the Vox AC15? (small note, I also use a Dynaco ST70 which uses an EL34 quad, could have been some long ago left overs.)
    As always thanks for your help, cheers.
  6. misterdontmove
    misterdontmove Tele-Meister
    Connecticut
    They have octal bases and would not fit in an AC15. I used to use these in my Marshall JCM800 and they sounded good and held up well.
  7. kbold
    Vox AC15 uses EL84's ..... not interchangeable.
    fyshnutz2 and northernguitar like this.
  8. northernguitar
    North of Toronto
    Nope...AC uses el84s.
  9. NTC
    NTC Tele-Holic
    Real 6CA7's sound more like 6L6'S. These look a little wider than some EL34'S, but certainly not as big as a 6CA7.
  10. NTC
    NTC Tele-Holic
    Double post
