JSMac
Hey all, I have a cheapo '70s Japanese amp the does't like sing coil pickups. As I turn the amp up there is a lot of single coil hum. Less in positions 2 and 4 but still pretty prominent.
The amp is Tempo. I haven't found much info on it. It uses a 12AX7, 6AV6 and 6AQ5. When I got it, it didn't have much volume or gain. I replaced the filter caps, upping the power supply a little. I played around with some mods to try to give more guts. Added a cathode bypass cap and upped the coupling cap values. Much beefier sounding now with probably too much gain past 12 o'clock on the volume.
Anyway, what would cause an amp to be so sensitive to getting single coils anywhere near it?
Adding on: The input area is very microphonic when I tap the wires or components around there and around V1. I swapped tubes so it's not that. I resoldered every joint from the input jack to V1. Beyond that point it is not sensitive. Any ideas what I should look for?
