OK to have alnico 2 in both neck and bridge?
Discussion in 'Just Pickups' started by thecrow, Mar 4, 2016.
  1. thecrow
    thecrow TDPRI Member
    upstate NY
    I am wondering if I can have an alnico 2 magnet p'up in the neck as well as the bridge? maybe as long as the bridge p'up is higher output?
  2. Derek Kiernan
    Derek Kiernan Friend of Leo's
    Princeton, NJ
    You would want to have a higher inductance pickup in the bridge, but that's almost always true. What are you trying to get out of your instrument?
  3. thecrow
    upstate NY
    I play mostly clean sounds. so if the inductance is higher in the bridge is it ok to have both the neck and the bridge alnico 2?
  4. HotDan!
    HotDan! Friend of Leo's
    Belleview, Florida
    Should not be a problem but consider how might want to cap 'em.
  5. Derek Kiernan
    Princeton, NJ
    What are you looking for from clean sounds? Why Alnico 2?
  6. thecrow
    upstate NY
    I already have an alnico 2 in the neck (SH-55) which I like a lot and don't want to change. the alnico 5 (STL-1B) that I had in the bridge had too biting of a treble response for me, so I wanted to add a Duncan that was a lil softer in that area. the only ones that matched that description just happened to be alnico 2's. I'm thinking the jerry Donahue lead now. the SH-55 measures 7.4k and the jerry Donahue lead measures 7.7k so I'm thinking/hoping it will work.
  7. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    Why would it be a problem?
    Typically you want more 'output' in the bridge because the tone becomes weaker and thinner, because of the pickup position, but I dont see how alnico 2 magnets would be any different.
    Gibson likes this.
  8. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    What guitar are we speaking of? Most people want Alinco 5 for the neck for clear articulate tone on most guitars. Seymour Duncan are making hybrid pickups for Strat and Tele that have A5 mags for strings 6-5-4 and A2 mags for strings 3-2-1 on both neck and bridge pups. They sound very good. Look up Seymour Duncan Five Two on youtube.
  9. Obsessed
    Montana
    AFAIK, there is no issue. I put Alnico IIs in neck and bridge on the same guitar. The main quest for me was trying to find different ohm resistance that could work with each other. As mentioned, it is basically a quest for what you want to get tone wise and that takes some research and some luck.
  10. jman72
    jman72 Tele-Afflicted
    Central Florida
    My Gibson SG has stock 490R and 490T pickups that are pretty standard- both are Alnico 2.
  11. ScottJPatrick
    ScottJPatrick Friend of Leo's
    Stirling, Scotland.
    I use an SD Donahue pickup in the bridge of my tele, paired with the SD alnico II in the neck but with the cover removed, works great for me.
  12. Platefire
    Platefire Friend of Leo's
    North Louisiana around Many
    I tried Stu-Mac Parson Street Alnico 2 in Neck and Alnico 5 in Bridge positions. I wished I had listened to the recommendations to put 2's in the bridge and 5's in neck. The 2's in neck position is too bright and the 5's in bridge is too mellow.
    So what happens is I set my amp to mellow out the 2's and the 5's bridge is to mellow. So you set the 5's bridge to have more bite and then the 2 neck is too bright. Just put the 2's in bridge and 5 in neck and be happy. Platefire
  13. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Have you considered Alnico 4 pickups ?
  14. thecrow
    upstate NY
    it's a tele, it's the kind with a single coil in the bridge and a humbucker in the neck. since posting I heard a lot of people use the seth lover SH-55/jerry Donahue lead combo in a tele and say it sounds great.
  15. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    I've got a set of Duncan Antiquities in one of my Teles. Both neck and bridge are alnico 2.
    Sounds great, love em.
  16. ItchyFingers
    ItchyFingers Tele-Afflicted
    Ottawa Ontario Canada
    I built my first Tele with SD alnico II Pro pickups in both neck and bridge.
    I would choose them again in a heartbeat if I built another single coil Tele.
    My ears and brain Love them. Yours may not.
  17. deadicated
    deadicated Tele-Holic
    Baltimore
    Got a set of Alnico 2 Pro's in one of my T- type guitars and they sound great to me. SD makes some quality replacement pick ups and a good exchange policy. I seem to like A2's over A5's but everyone has different ears and tastes so others will have other opinions.
  18. JD0x0
    New York
    My favorite setup is A3 in the neck an A2 in the bridge. The A3 is a tad 'softer' lower output, and to my ear 'chimey' while the A2 has a touch more output, and slightly smoother highs in comparison. Still nothing wrong with A2 in the neck and bridge.
  19. chris m.
    Santa Barbara, California
    I don't think A5 vs A2 is all that definitive on the overall tone of a pickup. It's the overall
    design that really makes the tone. While A5 may tend to be a touch clearer and brighter,
    that's only with all other things being equal.
  20. SPUDCASTER
    Grangeville, Idaho
    First rule of Telecaster.....There are no rules!
    SD recommends the Alnico II with the SD Jerry Donohue. Jerry used an Alnico II Strat neck pickup.
    What ever sounds good to you and works for you is the right choice.
    Welcome to the world of experimenting with the Tele.
