OK... so I promised... here ya are. . . .
Discussion in 'Stratocaster Discussion Forum' started by Ronkirn, Apr 14, 2008.
  1. milkshape
    milkshape Tele-Holic
    New England
    Well, I did some things right, and some things wrong. Thanks for the education. Really looks perfect.
  2. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    Well I reckon it’s time to wrap up the body, so let’s hit the back contour…
    I marked the rough location when I was marking the top contour, again, for those looking for precision in getting this exactly right, there was no “exactly right”. It was a hand process so it was pretty much to the shaper as he removed wood.
    Using pretty much the same method as I did on the top, I use the grinder to coarsely remove the wood down to the approximate depth. If this is you first try, Take a scrap of 2 X 8 pine, and cut the scalloped shape in it a few times. It’s not rocket science, it’s more an art, and while I’m no Leonardo, a little practice can’t hurt.
    I stand there and hold the grinder firm with my elbows anchored in my sides, and rotate from the waist; this makes it much easier to keep the radius consistent.
    Once it’s roughed in, you can take a curved block, I made this one from a piece of 2x4, glue a course grit sandpaper to it, and begin sanding away…when you get close, do the pencil thing again to give you a visual reference, change to a finer grit and continue ‘till it passes the sunlight test..
    Now, this is a relatively labor intensive method, so if you have access to a good oscillating spindle sander, you can make ya one of these racks to hold the body in position.
    The mistake many make on cutting this contour and the top contour are making then compound curves, they were not. In the sunlight shot above you can see the curve is only radiused on one axis.
    Ron Kirn
  3. Ronkirn
    Jacksonville, FL
    With the “jig” to hold the body I can move it against the spindle preserving the correct angle and keeping the floor of the contour flat.
    I just continue until I have the full deep contour seen in the 50’s and 60’s.
    The sunlight will tell ya when to stop…
    Now, I mark the edge as I did the top to give me an indication as I remove the hard edge and roll it into the round over.
    Using the convex sanding block I take the edge down to the first cut, then repeat taking it to the second cut. This illustration shows the 3 primary cuts, followed up with hand sanding to smooth it up into a continuous radius.
    rk
  4. Ronkirn
    Jacksonville, FL
    Here I have just about finished the roundover on the back side.
    Then after a bit of touchup with a finer grade of paper I give it the sun light test to note any gross irregularities.
    Some may be wondering how you get an acceptably consistent radius using a sanding block. It’s really quite easy. By moving the block down the edge it has a natural tendency to follow the previous line, cutting that line into “uncharted” wood. That, along with the sunlight’s shadow helps you know where the irregularities are lurking, so you can remove them.
    Now, there are two other operations to take care of….
    rk
  5. Ronkirn
    Jacksonville, FL
    The last thing to remedy is where we stopped the routing before we got to the Neck pocket’s heel. Using anything round with sandpaper attached, just smooth the abrupt edges into a continuous flow into the heel.
    I do one side, and then I do the other. . .
    Now I will go over it with a bit of sandpaper, about 150 – 200 grit, giving it a good look in the sunlight, checking to insure all it well and there are no looming foibles.
    The body is now complete.. all that remains is final sanding with 320, then the sealer, then the finish…
    I’ll begin that later this week….
    Ron Kirn
  6. ehawley
    ehawley Tele-Afflicted
    Keyport, New Jersey
    My, My Mr. Kirn!...You certainly are the StratMan Mr Kirn! That is one beautiful job. It was very informative on the front contour. I've seen it done where it was just a flat cut, but that never really looked right. I put a straight edge on my california series strat a sho'nuf'. It is a rolling curve. Great job and a lot of valuable info in this thread. Thank you!
    Cheers
    ED
  7. WisconsinStrings
    WisconsinStrings Tele-Afflicted
    Arcadia, Wisconsin
    Very educational. I'm really enjoying this.
  8. tuuur
    tuuur Friend of Leo's
    the Netherlands
    Just... wow.
    Amazing thread again, Ron. Can't wait to see how this one will turn out. (though I guess exactly that is the trick, patience... :D)
  9. milkshape
    New England
    I imagine the sitka is soft, how do you keep from getting dings and scratches when moving it around router tables and stuff like that? I always seem to get a scratch somewhere.
  10. Jimo
    Jimo Tele-Afflicted
    Obeleo
    Is that a Willis Alan Ramsey reference...OBELEO...?
  11. Ronkirn
    Jacksonville, FL
    It's about as dense as Alder, and I keep the router table surface free of foreign material...But is a dent does occur, a drop of water, a paper towel and a hot iron erases it, followed by a light sanding and it's gone.
    Ron Kirn
  12. milkshape
    New England
    Thanks the iron is a great trick I'm going to try out on an alder body that had a tool dropped on it. The rack on the spindle sander is another one. Thanks again for taking the time.
  13. Scotland
    Scotland Poster Extraordinaire
    Aberdeen, Scotland, Yewrup
    This is so addictive. I am going to Tenerife for a week's holiday on Friday and guess what ? I've got something to look forward to when coming home.
    Thanks Ron.
  14. SMPTE
    SMPTE Tele-Afflicted
    Minneeeesoooottta
    That's really incredible Ron, great workmanship!
    Great job!
  15. Arlo
    Arlo Friend of Leo's
    Upta Camp
    I am speechless Ron!! Great work as always bro!
    Thanks for the heads up on this build. I don't get in the Strat section of the TDPRI anywheres near as much as I should being a Strat man for the past 33 years.
    Can't wait to see the finished deal. Amazing!
  16. Southern Ill
    Southern Ill Banned
    Illinois
    Amazing.......
  17. Southern Ill
    Southern Ill Banned
    Illinois
    Hey Welcome to the forum....You are in good hands....Seems to me ya know whatcha want....Have it built how you want it.With it being spruce I would love to see it natural or with a light toner like a older Martin ....Again very nice git'....
  18. boris bubbanov
    New Orleans, LA + in the
    Great thread
    I'm getting the distinct impression that this guy from Jacksonville knows what he's doing, maybe?
    Thanks, Ron.
  19. Ronkirn
    Jacksonville, FL
    Gotcha all fooled...:lol:
    I'll be starting the finishing in a couple of daze... hang in there.
    Ron Kirn
  20. Gr8tfulEd
    Gr8tfulEd Tele-Holic
    Lake Oswego, OR
    'scuse me while I pick my jaw up off the floor.
