oil finish on mahogany
Discussion in 'Finely Finished' started by funkymann1, Jul 30, 2016.
  1. funkymann1
    funkymann1 Tele-Holic
    Cooper City Florida
    looking to do a raw finish with gun stock oil on a mahogany body, my question is after the few coats are wiped on how do you polish without getting compound in the pours?
  2. Dunkerhook
    Dunkerhook Tele-Meister
    New Jersey
    I've only finished mahogany necks with tru oil, but I had no trouble. The tru oil fills the pores after a few coats. The tru oil doesn't need much sanding -- I start at 320 and go up to 600. Then I use micro mesh pads until I have the necessary glossiness.
  3. richa
    richa Tele-Afflicted
    Are you wanting the pores to stay open or are you concerned they won't fill in the number of coats you plan?
  4. Tony Done
    Tony Done Friend of Leo's
    Toowoomba, Australia
    I did the front of my uke and my kona with Danish Oil, which is similar to Tru Oil. It did a good job of bringing out the grain in both of them, and if you apply enough coats (I used a fad, as French polishers do) you get a pleasing low gloss. However, I wouldn't try polishing it.
  5. funkymann1
    Cooper City Florida
    Dunkerhook
    True oil does not fill pores....i dont know what crack your smoking & this is one of the reasons i dont hang in here often anymore...to much wrong info..
    this is the finish im going after & it was obviously polished some how at the fmic factory after the caseys oil was applied.
  6. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    The hell it doesn't. If you apply enough coats it will look as deep as any poly finish does, and just as slick.
    Tru-Oil is not the same as a linseed oil finish. You don't polish a linseed oil finish, you layer it on and buff it off with steel wool, and repeat about seven hundred times. It doesn't create a slick, hard surface, and won't fill pores. On a porous wood you'll only end up with a sticky mess.
  7. dsutton24
    Illinois
    Quadruple post
  8. dsutton24
    Illinois
    Septuple Post
  9. Larkins
    Larkins Tele-Meister
    Bay Area, CA
    Any finish will fill pores with enough coats
