Ohms... please simplify
Discussion in 'Amp Central Station' started by RRodgers, Apr 16, 2021.
  1. RRodgers
    RRodgers TDPRI Member
    Union, SC
    Orange crush60 pro. The out put jacks say 1x8, 1x16 or 2x16.
    Now the problem is, it's going to a mini cabinet with 4, 8in speakers.please help
  2. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    By ohms, you are looking for the impedance of the amp.
    The number of speakers isn't as relevant as what the impedance of the speakers is, and how they are wired.
    Why don't you post pics of the output of the amp and the input of the cabinet?
    Using google I found this:
  3. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    You could load one 8 ohm cab or one 16 ohm cabs. Or it will power two 16 ohm cabs.
  4. Wally
    https://orangeamps.com/wp-content/uploads/2016/04/Orange-Crush-Pro-Series-Manual-V16.pdf
    You have a solid state amp there. It does NOT want to see less than an 8 ohm load per the manual. You are putting your amp at risk by running a 4 ohm load. Running a solid state amp with a lower load than the design calls for puts the output transistors at risk.
    The manual is your friend. You can run a s8ngle 8 ohm load. You can run 2 x. 16 ohm loads for a total 8 ohm load. You can r7n a single 16 ohm load with the resulting loss of approx. 50% of power. To continue to run that 4 ohm load, you risk losing all output power.
    Torren61 and northernguitar like this.
  5. AlbertaGriff
    I don't think he's saying 4 ohm load, I think he's saying it has 4x8" speakers? I don't think he knows the impedance of the cabinet.
    Wally and northernguitar like this.
  6. Wally
    well, I misread it incorrectly twice!!!! I mentally added ohms after the 4 because the drift of the question was about ohms...my deep apologies. Everything except my warnings still holds, and manuals are your friends.
    AlbertaGriff likes this.
  7. Wally
    Oh...and I was wondering how the amp had not burned down with a 4 ohm load. thanks for the wake up call, AlbertaGriff.
  8. AlbertaGriff
    It's a tough one because he didn't say ohms with the output, but they were all ohms as well.
    He had another thread earlier today about this same subject which when put together helped clarify.
    Wally likes this.
