Oddball project
Discussion in 'Tele Home Depot' started by Clintstone, Nov 11, 2019.
  1. Clintstone
    Clintstone Tele-Meister
    Brandon Manitoba
    So a good buddy of mine brought me his old guitar to see if I could fix his neck. Apparently it got knocked over and has a little crack. So when get looking at it the neck is broken almost all the through at the headstock. Closer inspection revealed that a few of the frets have some bad spots as well. After some discussion we decided to just make a new neck for it as it is a bolt on and shouldn't be too difficult. The guitar in question is his old Harmony flying V, that he used to play in his old punk band. He plans on doing something weird with the body paint scheme so he wants an off the wall looking neck to go with it, something unique. This is what I came up with. 20191111_204028.jpg
    Barncaster, nnieman, tnt423 and 7 others like this.
  2. Deeve
    Deeve Friend of Leo's Silver Supporter
    Ballard
    looks good
    show progress through to installation
    Peace - Deeve
    crazydave911 likes this.
  3. Clintstone
    Brandon Manitoba
    Got my holes drilled for the fret markers tonight
    crazydave911, nnieman, CraigB and 2 others like this.
  4. Clintstone
    Brandon Manitoba
    I feel like I Ninja every time I use this fret slotting saw lol. 20191116_133745.jpg
  5. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    Well you look like one too!:)
    Nice work there.
  6. Clintstone
    Brandon Manitoba
    Well I had a slip with my saw and ended up with a crooked slot. I decided I could salvage this fretboard, luckily i didn't cut it very deep yet. I decided to pick up a 0.022" end mill and cut the slots on my milling machine. I managed to cut all 22 slots without breaking a cutter, .002" at a time. People tell me I have more patience than brains. 20191205_202655.jpg
  7. Jim_in_PA
    Jim_in_PA Tele-Holic Ad Free Member
    SE PA near New Hope PA
    I use a .022" end mill for cutting fret slots and after having a conversation with Ron at PreciseBits, I kicked the speeds and feeds up a bit...to my surprise, the little cutter handles it very well at 24ips at 18K RPM with five passes to a total of 2mm depth on my CNC. So as long as your milling machine's movement is consistent, I don't think you'll have any issues using that method to cut the slots if you want or need to use it.
  8. Clintstone
    Brandon Manitoba
    Forgot to mention I am feeding by hand and my mill maxes out at 2000 rpm. I am really surprised I sisnt break a cutter.
    Barncaster likes this.
  9. Jmwright777
    Jmwright777 TDPRI Member
    Idaho
    Cool design! I feel its fits the flying V way better that the arrow headstock!
  10. Jim_in_PA
    Wow...holy slow rotation, Batman!!! :)
  11. Clintstone
    Brandon Manitoba
    At 1.808" wide this is hands down the widest neck I have built. My friend that I am making it for has huge hands and doesn't find most electric guitars comfortable to play. This one at around 1 13/16" should be more to has liking. It will probably be close to an inch thick as well, "we cant stop here this is bat country." 20191206_213601.jpg
