PhredE
Have you measured the pickup height (are they close to Fender specs)? If the other stuff doesn't elminate it, I'd lower the neck pickup and check again.
Still does it with the ceiling fan off. I tried headphones too thinking maybe something else in the room was vibrating but it's just coming from the guitarWhat @Doorlord said is worth checking out. Turn off the ceiling fan and try checking. Also, a fluorescent light of any kind can be a problem too.
there's a couple but it's not them. The overtone happens through headphones as well.Is there an acoustic guitar in ear shot?
I'll give that a shot putting something behind the saddle. I had the stainless Bensonite saddles on there. No issues with them but thought just in case I could swap them out with the original Fender CS saddles and no change other than missing the feel of the Bensonites. I tried swapping a different brand of strings too and no luck. I checked under the bridge plate and nothing weird. Nothing lose I can find anywhere. Tried playing the notes that trigger the overtone and touching other parts of the guitar but nothing is showing up. I tried putting cloth in different areas of the fretboard between the strings and no luck either. Other than a fret job or changing out the pickups (which I don't want to do) I don't know what's left.I was just checking the design of the saddles
Best telecaster saddles on the market.
Fix the intonation on your tele with these compensated telecaster saddles from Bensonite - improved intonation, shorter set screws for improved feel, and slots to maintain proper string alignment. These saddles look, sound, and feel amazing.www.bensoniteproducts.com
Are any of your saddle pieces touching the bridge plate directly? or are the adjusting screws raised enough to get the saddle piece(s) up off the bridge plate?
Edit: Is it possible the bridgeplate mounting screws (the head) protrude and contact either: one of the saddles, or one of the saddle height adjusters?
Another thing I would try is to place some softer material object like a pencil eraser, a neoprene grommet/washer, etc in contact with E, B strings to deaden any possible sympathetic vibration behind the saddle (eg; between saddle and where it descends into the thru body).
I use an appropriated sized grommet wedged between adjacent strings (B and E usually) and it does a good job of taking care of weird sonic anomalies like that. I would try it at the bridge end AND up between nut and tuner/string tree too.
There had been some cases (not for me personally, but other issues with posters here on TDPRI) where people observed the same.I'll give that a shot putting something behind the saddle. I had the stainless Bensonite saddles on there. No issues with them but thought just in case I could swap them out with the original Fender CS saddles and no change other than missing the feel of the Bensonites. I tried swapping a different brand of strings too and no luck. I checked under the bridge plate and nothing weird. Nothing lose I can find anywhere. Tried playing the notes that trigger the overtone and touching other parts of the guitar but nothing is showing up. I tried putting cloth in different areas of the fretboard between the strings and no luck either. Other than a fret job or changing out the pickups (which I don't want to do) I don't know what's left.
Like the title says. Just heard it for the first time last night. Thought it was a power tube in my amp but then tried my Strymon Iridium straight in and it's there too with my Tele. If I play the high E or B separately, no issue. But when I play them both together on the same fret, ex: F# on the E string and C# on the B string, Fret 14, I get a weird low F# octave that appears. Seems to happen with both pickups, the more gain the more it emphasizes it. Fuzz really makes it really obvious. It's on the octave but it's not pretty. Swapped the strings out and nothing changed. What an odd issue. Open to suggestions? An odd Tele ghost?
Video of Tele and Iridium. You can here those weird low tones
Truss rod seems fine. I just did a fret job on it and it didn't fix it. But if I hold the body to my ear I can hear the low overtone resonating slightly in the body. I do not hear it on the neck. If you've never held your Tele neck or body flat to your ear, its' crazy how loud it actually is hahaha. So my guess is it's not the pickups. But something in that guitar is resonating in a strange way. Glad y'all can hear it too in the video and I'm not crazy.Man that is obvious and weird!
Does it do it unplugged?
HAVE YOU CHECKED TO SEE IF THE TRUSS ROD IS LOOSE?
Did you try turning the truss rod just a bit to tighten it? I had a Fender Strat that had a weird vibration once and that was the issue, the truss rod was at neutral with no tension so rattling in the groove.Truss rod seems fine. I just did a fret job on it and it didn't fix it. But if I hold the body to my ear I can hear the low overtone resonating slightly in the body. I do not hear it on the neck. If you've never held your Tele neck or body flat to your ear, its' crazy how loud it actually is hahaha. So my guess is it's not the pickups. But something in that guitar is resonating in a strange way. Glad y'all can hear it too in the video and I'm not crazy.
The example used in that case is for acoustic instruments having interior air chamber(s) -- it doesn't really apply to your case.Also, found this article. Seems relatable:
https://www.sweetwater.com/insync/wolf-tone/
Interesting. I just did the frets yesterday but didn’t notice anything. Maybe an experienced tech would be worth looking at itI had a similar thing happen to a Jazzmaster. It was also intermittent and was about to drive me crazy. In that case it was a loose fret, not really noticeable in any way except for a strange harmonic when playing two strings at once on it. I gave it to a tech who dropped some very thin CA glue along the fret so it soaked in and then re-seated the fret.
Before or after the problem manifested?I just did the frets yesterday
