OD/Distortion recommendation for a JC
Discussion in 'The Stomp Box' started by schenkadere, Oct 20, 2020.
  1. doghouseman
    doghouseman Tele-Meister
    in your head man....
    someone once told me Boss tests their pedals with JC amps. So, I would recommend some kind of Boss pedal. THe Boss power driver is great for super high gain.
    schenkadere likes this.
  2. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    Getting back to the stereo/full range design of this amp, it dawned on me that you might actually get decent, or even good or great results, if you tried a full-on modeling/DSP pedal, probably to include cab sim, which probably uses IR. And - you might even want to find one with stereo outs.
    ...The whole idea would be to try and leverage the full freq. response of the JC-22's design, almost as if you're using it as a P.A. of sorts. And since the chorus is leveraging the benefits of stereo, you could possibly get the same thing from a really good non-mono/non-analog processor.
    Amps like the JC-22 might even excel when used this way.
    So, the JC-22's overall design, to include the speakers, is probably the actual limitation, if approaching this from a traditional way. Treat the amp as if it were a compact stereo P.A., and the limitation(s) could potentially become strengths.
    Now - as to affordable stereo modelers - I'll kindly defer that to the other experts here. Well, and I'll add that I got a used Atomic AmpliFIRE about a year ago, and it's been great, but I only use it with headphones, and (even used) it costs not much less than a new JC-22. Hopefully, there's something decent that's more affordable by Mooer/Zoom/Nux/Line 6/etc...
    doghouseman and schenkadere like this.
  3. Tornado
    Tornado Tele-Meister
    Amsterdam
    Just pick a distortion or overdrive you like. The Jazzchorus series from Roland are excellent as a clean platform for pedals.
  4. schenkadere
    schenkadere Friend of Leo's
    NY
    I have, and they're not to my ear, lol.
    Tornado likes this.
  5. schenkadere
    NY
    One thing I did not try is switching on the cab sim on the Dapper...duh! I'll try that tonight and see if it makes a difference.
  6. schenkadere
    NY
    That does make sense...but these are 2 tiny speakers. I doubt this is the testing platform.
    doghouseman likes this.
  7. doghouseman
    It might be hard to find a distortion that works well with that amp. Have you tried a tube screamer?
    You should take advantage of the clean stereo sound. A stereo sound is huge and fun to play.
  8. schenkadere
    NY
    TS sounds like doody so far...gonna try the cab sim tonight.
  9. Bluesbrother777
    Bluesbrother777 TDPRI Member
    Baltimore
    I have a JC40 that loves dirt pedals. The ones that sound best though are specifically made to be played into a clean amp and that’s what you should be looking at for most bang for your buck I think. Amp in a box pedals are probably good, digital modelers like Boss MDP pedals, etc.
    I personally have the Wampler Velvet Fuzz and Way Huge Fat Sandwich that I can recommend as both are meant for high headroom clean amps.
    Last but certainly not least, new JC amps are really bright with treble at noon. I run the treble on mine between 9:30 and 10:30 at most. This is crucial for decent distortion tone but also clean tone, especially single coils (this is TDPRI after all) It’s a tip I picked up on YouTube and I’ve been much happier with the amp since.
  10. schenkadere
    NY
    I know my tone! Clean or dirty. Don’t you worry. I am a super picky dirt lover!
    I honestly think 11 Gauge nailed it with the speaker size and type.
    Regardless, I love the amp for what I purchased it for...CLEAN. It don’t get much cleaner!
  11. Axegrinder77
    Axegrinder77 Tele-Afflicted Ad Free Member
    Springtown
    Od pedals are to push tube amps into distortion.
    You probably want a distortion pedal, generally meant to turn a clean channel into, well, distortion.
    DS1 or 2 seem like worthwhile starting points.
    I have a Wampler Sovereign on my board right now. It's great.
  12. schenkadere
    NY
    I've been playing over 40 years. I've been through a ton of dirt pedals as well as all other gear. I think the trick here is to treat it like a PA.
    I can hear a DS-1 into this amp in my head without even trying it and I can't imagine that working.
  13. radiocaster
    europe
    You might want to try this.
    It has a built-in cab simulator. In fact I don't even like it through a regular guitar amp, it's too bassy. Sounds great through a boom box or stereo. You have to crank the mids (voice knob) to get more distortion, but it doesn't sound gross like you would expect.
    There's also an Orange version, which I haven't tried.
  14. NWinther
    NWinther Tele-Afflicted
    Denmark Solbjerg.
    ThermionicScott likes this.
  15. doghouseman
    Yes!
  16. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    I think the ideas discussed about the speakers and thinking of it as a PA are great ideas.
    The description to me originally seemed like sort of an overloaded ‘digital’ input problem. I know it’s not digital, just saying try the pedals at unity or below to make sure - if you haven’t already.
  17. schenkadere
    NY
    Unity for sure...first thing I did when it sounded funky was check that.
    ScribbleSomething likes this.
  18. 11 Gauge
    Near BWI Int'l
    If you've ever played your guitar and traditional drive boxes straight into something like a home stereo, it probably becomes clear that it's not an input or level problem, per se, or at least it's not limited to just driving the stereo's preamp into clipping.
    A traditional guitar amp only really reproduces frequencies from about 100Hz to 5KHz. Also, there are typically circuit-level mechanisms to soften or attenuate harmonic distortion, and create non-linear output signals. The power amp and speakers also play a big role with this.
    Our ears really object to hearing upper-order harmonics in anything more than a tiny amount (e.g. really anything higher than 4th harmonics), especially the odd-order ones. That's what many traditional drive boxes make. Any hi-fi system will typically faithfully recreate them in excruciating detail.
    W.L.Weller likes this.
  19. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    Good OD/distortion tones are more important to me than stereo chorus. I'd probably be looking at trading the JC-22 for something more conventional. It's a shame that the Roland has no extension speaker jacks. Treating the amp like a PA sounds like a good idea, I guess, but not every PA sounds great. You could try plugging into the FX return to see if the speakers are actually the problem. If the speakers sound OK, maybe an EQ pedal would help.
  20. schenkadere
    NY
    I've got great distortion tones with my Randall. Again, this was purchased specifically for the cleans and for home use. I got such a great deal on this Valeton Dapper that I couldn't pass it up thinking it would be perfect for the JC. I didn't get a chance last night, but I think turning the cab sim on the Dapper might just do the trick.
