Endless Mike
So this might be part III in an unintended trilogy regarding modifications to this fine yellow box of sound.
I've sorted out the gain issue, for those of you who witnessed that low level fiasco. So here's where it stands now. The four component mod to reduce the bass frequencies that get clipped, in order to eliminate the spitty/crackly decay, and the overall 'boominess' of the OD-3 works, and it works well.
So here's what's new. I'm not using the amp I once used with this. While the OD-3 still sounds great, it now sounds a bit congested through my current rig. So I'm looking to open up the sound a tad. Not too much, just enough.
Some would say tag a BAT 42 onto the 1N400x put in place of the stock diodes at D10/D11. Don't want to do that, as that's clamping things down in order to help correct the decay issue.
I'm thinking maybe make some changes to diodes D6/D7, but the question is what? Maybe the idea above, 1N400x in series with a BAT 42 at D6/D7? Maybe something else? Pulling C35 as in the "accidental OD-3 mod"?
I'm open to suggestions, the only caveat is that it needs to be simple, no more than four or five parts changed *at most* The fewer the better.
Thanks!
Thanks!
