Driveout02
Ok.. I'll admit up front that I just posted a very similar question about a week ago.. but I've done some research and changed some of the parameters of my search, so maybe you can help me find this amp:
1. Combo amp with only one channel that does cleans really well. Any overdrive I need I can get from a pedal- I prefer it relatively clean anyway.
2. Very simple controls (e.g. Vol, Bass, Treble, Mids, or even just Vol, Bass, Treb- and spring reverb would be nice so I suppose there'd be a reverb control as well)
3. 30 or 40 Watts.. any less wattage it breaks up too quick at the volume I play at
4. Well made without breaking the bank (I originally said around $800 I believe, but after some research, realize the kind of amp I'm looking for will cost at least $1200, so I suppose that's my new cost floor)
It seems a lot of the amps I come across are almost there.. but either it has two channels (seriously, I don't use the gain channel.. so I don't want it.. more to go wrong), or some pre-set EQ switch (fender, marshall, vox-like sounds, more drive, clean boost, etc.). I want no switches.. unless it's on/off or standby.
I've looked at Mesa, Dr. Z, Traynor, Divided by 13, and a few others, and some models come close, but some are too expensive, and really none fit the bill perfectly. If I'm gonna spend that much money, I want it to be right. And anyway, why am I having such a hard time finding an amp that's seems like such a simple, no-brainer design?
Thanks again for your help!! Take care.
