Nut slots spaced too narrow? (photo attached)
Discussion in 'Tele-Technical' started by Thoughtfree, Nov 26, 2020.
  1. Thoughtfree
    Thoughtfree Tele-Meister Silver Supporter
    Minneapolis MN
    Here's the stock nut on the Muslady Strat kit I assembled recently. I am thinking that the two E strings should be closer to the edge of the fingerboard - do you agree - should I make a new nut with wider spacing?
    The nut is 42 mm in width - narrower than I prefer - so if I can widen the string spacing a little, this kit guitar will be a bit more playable. I have nut blanks and nut files, and have made nuts before. Thanks, folks, for your opinion.
  2. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
    That looks a little narrow...but if it plays alright, tweak the rest of the guitar and get back to a new nut sometime. Set up the outside strings and space it from there.
  3. trev333
    Coolum Beach,Australia
    a 43mm nut might work.....
    I'm more worried about the E-E measurement.... usually @ 35mm for mine...
  4. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    My recent experience with some VM Squier Thinlines is the opposite -- high E string slots too close to the side... Add a bit of vibrato and you fall off the deep end -- I'd rather have your issue than this one. I like 2-3/32" from each E string to edge of the fret top before bevel.
    Doctorx33 and boris bubbanov like this.
  5. charlie chitlin
    Kimberton
    All depends on how you feel about string spacing. No rule says you have to use all your fretboard.
    I generally start with the strings 1/8" from the edge of the fretboard.
    Tuxedo Poly likes this.
  6. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    It does look like too narrow of a string spacing for the fretboard width.
    I prefer my outer strings closer to the edge of the board. I don't mind as little as 1/16", myself. 3/32" is a good sweet spot IMO. It looks like you have 1/8" or more. That can work OK with a wide nut, but it makes things really cramped on a typical Fender guitar neck, with its 1 5/8" nut width.
    The more space there is from the edge of the board to the outer string, the more "roll" I like on the edges of the board.
  7. kingofdogs1950
    kingofdogs1950 Tele-Afflicted
    Franklin, Texas
    I'm usually happy with stock string spacing,
    but the spacing on my Yamaha AES620HB just felt cramped.
    I replaced the nut with a Tusq pre-slotted that was a perfect drop in fit with minor height adjustment.
    Its not a huge difference, but I like the Tusq nut, both for the wider spacing, but also for the built in lube.
    Happy camper.
    M
    tintag27 likes this.
  8. boris bubbanov
    New Orleans, LA + in the
    I've got seven of these MIM Classic Player 50s Bajas, and just one of the seven has a weird nut array like that.
    I found I could adapt to it readily. I really like it a lot, now, therefore not going to mess with it.
    However, my overall nut width is a little over 1.650 inches. I'm excused from doing math tonight - if your neck is decidedly narrower than that, you might set my advice aside as not useful.
    I agree with DavidP - slots too close to the edge are a bigger problem.
  9. Thoughtfree
    Minneapolis MN
    Thanks, folks. Not a giant issue for most of my playing, but open-string cowboy chords low on the neck can be problematic on this guitar. Probably a new nut will have to happen.
    boris bubbanov likes this.
  10. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
  11. Thoughtfree
    Minneapolis MN
    Thanks for the nut layout docs!
  12. schmee
    schmee Doctor of Teleocity
    That's a bit more from the edge than usual, it only matters if it doesn't feel right to you though. Too close to an edge may be a worse issue. Just buy a pre slotted nut.
  13. fenderchamp
    fenderchamp Friend of Leo's Ad Free Member
    omaha
    this is sort of liking saying "I have toilet paper" and asking us if you should wipe.
    Get on with it already.
  14. Thoughtfree
    Minneapolis MN
    Good advice.
