NUAD Marshall Class 5 With a Question
Discussion in 'Glowing Bottle Tube Amp Forum' started by Joe M, Oct 6, 2019.
  1. Joe M
    Joe M Super Moderator Staff Member
    Michigan
    Admin Post
    Just picked up one of these in mint condition. Newest generation with the three piece back. Original tubes, don't think it was ever played, just sat in somebody's music room. As great as it sounds, and as loud as it is (5 watts????) it has an annoying hum after the tubes warm up. Doesn't matter if anything is plugged in or not, it's always there. Changing any of the knobs makes no difference. Tried a new set of tubes with no change either. Probably being anal since you can't hear the hum when you're playing. So, is there any fix or just live with it?
    Thanks
  2. corliss1
    Lansing, MI
    If swapping the tubes didn't do it, it's probably just how it is. Unlike older amps, it's all one big board so there aren't any wires to chopstick around.
    It helps to know what kind of hum - 60 or 120Hz? That would at least isolate the issue. I suppose it's possible there is a bad filter cap even on a newer amp that would cause this.
  3. printer2
    Pull the tubes, if the hum is still there it is the power transformer coupling with the output transformer. If no hum plug in the output tube. It is a single ended circuit and they are more hummy than push-pull. If no hum then plug in the next tube in line. Check for hum then plug in the first tube. Not much more that you can do without a little experience under the hood of the amp.
  4. Joe M
    Michigan
    Admin Post
    Thanks for the replies, guys, think I’ll just live with the hum.
  5. Les Paul lover
    Les Paul lover Tele-Holic
    England
    Is there a hum balance pot somewhere on the board of the Class 5?
    My Orange AD5 hummed like crazy until I tweaked the hum balance pot in the correct zone.
  6. MuddyWolf
    MuddyWolf Tele-Meister
    Paradise, Ca
    I think i remember the hum is a common complaint with those.
  7. metropolis74
    metropolis74 Tele-Holic
    Minnesoter
    All single ended amps have idle hum to some extent. It's the nature of the beast. Do you have another SE amp to compare the hum to?
    For example my Class 5 hum is quieter than my Champ 600 reissue hum. But when playing the hum is not noticeable on either amp.
  8. metropolis74
    Minnesoter
    No hum balance pot on the Class 5. There is an artificial center tap on the heater circuit of two 100ohm resistors to ground though.
  9. noname_dragon
    noname_dragon Tele-Meister
    North east coast
    A loose or disconnected ground somewhere in the engine room can cause full-time hum I had an amp with that issue and once corrected the hum was gone.
  10. gusfinley
    gusfinley Tele-Holic
    SLC, UT
    The artificial center tap trick works pretty well, but is not foolproof. If you put 5% tolerance resistors in there you could end up with a 10% imbalance.
    I like to use 100 ohm 1% tolerance resistors. They can make a noisy heater hum dead silent!
    If you reference the heaters to an elevated voltage ( like the cathode of the power tube ) this can help lower the hum also,
    That is IF the heaters are the source of your hum.
    What tubes do you have installed?
  11. Joe M
    Michigan
    Admin Post
    Thanks again for all the tips, guys, but I've made my original question moot.....couldn't stand the hum, so I returned the amp.....:rolleyes:....told you I was anal....
  12. corliss1
    Lansing, MI
    Not having the amp will make the hum less for sure!
  13. Joe M
    Michigan
    Admin Post
    :lol::lol::lol::lol:
  14. tubelectron
    tubelectron Tele-Holic
    France
    Hi @Joe M ,
    The plate voltage on the Class 5 is not filtered enough, using a 220R/5W resistor (R6). Replacing it with a choke (the 194A for Fender Champ is fine) along with boosting the 2nd filter cap from 47 to 100µF/500V would certainly eradicate that hum. It's what I will do on my Class 5 combo ASAP.
    These 2x 100R (R16, R17) resistor hum balance are already existing, plus the 12AX7 tubes are DC heated and filtered (C16 to C19 : 3300µF). Little chances of hum source here...
    -tbln
  15. gridlock
    gridlock Friend of Leo's Silver Supporter
    Tampa, Fl
    Congrats a very good amp.
    I owned a new-version 2012 Marshall Class-5 (.1 watt switch on the back). I don’t recall any hum and it was a good sounding amp. Sold it because I also owned two Marshall 18 watt EL84 amps at the same time. I do miss the .1 watt setting on the Class-5.
    Please post some photos.
  16. corliss1
    Lansing, MI
    @gridlock - someone didn't read the thread :D
    gridlock likes this.
  17. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    I know you have returned it....(I did read the thread :) )
    But as another reference point my Class 5 v1. doesn't hum beyond normal cranked gain / volume.
    At sane levels it is pretty quiet.
  18. gridlock
    Tampa, Fl
    Oops...skim reading. Glad that I didn’t post a picture of my old Class-5.
