W.L.Weller
I'm starting off on the wrong foot by waiting to post photos, I know. A little googling and youtubing seems to suggest that these are pretty decent guitar amps "stock".
http://makearadio.com/schematics/index.php
Half of a 6EU7 as the input stage, a Baxandall tone stack using a 12AX7, a cathodyne phase inverter using a 6C4 and a pair of push-pull 6L6.
I'm going to order filter caps and check the coupling caps for DC leakage, as well as the rectification diodes; anything else I should check prior to firing it up? These use a voltage-doubler power supply, someone else noted that the 100μF capacitors should be the best you can get:
https://organforum.com/forums/forum...s-accessories/50213-bogen-chb-50-amp-question
<<This amp uses a voltage-doubler B+ power supply, so use the highest-quality electrolytic capacitors you can find for the 100uF caps in the doubler circuit. They get charged and discharged more on each rectification cycle than standard reservoir capacitors.>>
And a few posts from back in the mists of time here:
https://www.tdpri.com/threads/bogen-chb-50-conversiin-suggestions.366277/
https://www.tdpri.com/threads/building-a-bf-clone-from-a-bogen-pa-head.379455/
Anyway, swapping the input and output connections for 1/4" jacks is my first order of business (because I have those parts in stock.) And I don't think I have the appetite for replacing the PT, so I'm going to service it and see how it sounds "as-is." Maybe I'll try swapping the 6C4 for a 6J6 if only because I have a dozen 6J6, but I haven't looked at the pinout yet. Plus, NOS 6C4 are only a couple bucks, unlike the rest of the tubes this amp uses. Pics to come.
