Raezzordaze
So I just finished redoing a build that was basically a clone of the AA764 Vibro Champ but without the vibrato, so one 12AX7, one 6V6 and a 5Y3 rectifier. This is more or less the schematic. I modified the schematic I had since it was from a book of easy DIY home builds. I built it using point to point wiring and a homemade chassis and it turned out well. However, no matter what I did I couldn't get the amp to drive the 6v6 to full power and start breaking up. Even with a humbucker-equipped guitar.
I originally used a Classic Tone 40-18019 with a 325/0/325 HV secondary which I felt was high. Also, the guy messed up his the inputs so both hi and lo had some at least 6db attenuation. So I went to a single input with a 1meg leak and a 34k grid stop like this. I also swapped to a different PT that has a 300/0/300 HV secondary, the Hammond 272 BX. I also wanted a cleaner layout so I swapped to a turret board and used individual power supply filter caps instead of a can.
After I completed the build initial testing produced a somehwat reduced volume and very slight but noticeable high frequency squeal/oscillation that would disappear when volume or bass/treble were reduced, also disappeared when the power tube was pulled which.. I mean... duh. Also, turning off the feedback made the squeal slightly louder when it was present.
Initial trouble shooting showed me that I had a few connection that weren't right so I fixed those and the noise persisted. Tried moving a few wires to reduce feedback/induction/etc and no luck. Then I noticed that I had the 115V primary lead connected instead of the 125 volt. So I took some voltage readings and was really shocked to find something out. At the input to the first filter after the rectifier it was showing 370 volts (on the schematic I linked it shows 360 so not bad.) However, when I read on the plate itself, to ground, it showed 338 volts... a drop of over 30 volts across the primary of the OT which, btw, is a Classic tone 40-18030. Furthermore, I had added a 1k ohm screen resistor (and a 1.5k ohm grid stopped resistor) to the 6v6 to try to stop and oscillation, and I found that even though I had added that, my screen voltage was actually HIGHER than my plate voltage at 352 volts (the voltage on the other side of the screen resistor was 358 volts, so dropping 6 volts across it... guessing that the 6ma that the screen is pulling is high but in line with these voltages...) Additionally, I also noticed the damn bias at the top of the 470 ohm cathode resistor was 21 volts!!! I couldn't find any characteristic curves for a 6v6 that were anywhere close to these plate/screen voltages, but I was pretty sure that was a lot closer to cutoff then I liked.... so I guessed that the higher plate and screen voltages were pulling far more current than the original design called for...
Swapping to the 125 volt primary lead on the PT did reduce voltages to where I wanted them. The 370 earlier was reduced to 335. The plate is sitting around 305 now so still getting that large drop. Screen is at 320ish though so still higher than my plate. I checked the bias and it was still freaking 20 volts so I dropped that to a 220 ohm and got that down to 13ish volts. (I've been looking at some of my design books and articles and after crunching the numbers I do realize that is a bit low and causing the 6V6 to red plate a bit so I've ordered some 360ohm 2W ressies which should get the bias where I would like it.)
Side note here, the squeal is gone and I am getting full volume out of the amp now... and getting some deeeeeeeelicious SE class A growl at full volume. Feedback turned off to make it a bit juicier!
So I have 2 questions here.... number one, is that large of a voltage drop normal across these small OTs? From the tube amp design theory books and articles I've read, they generally say the voltage drop across an OT primary can be safely ignored in the design phase as it usually isn't more then 5-10 volts... so do I have a bad OT? Or is it a bad 6v6 with a lower than normal plate resistance causing a larger than normal current draw? I unfortunately don't have a spare 6v6 or access to any, and really don't have the funds atm to be buying parts willy nilly to test.
And second... should I raise that 1k 1W filter/dropping resistor to 2.2k or even higher, or the 1k screen resistor (actually, both of those resistors are 2W to be safe... didn't feel comfortable using 1W resistors in this...) to bring the screen voltage down to at least the same as plate to ground? Or reduced it to be a bit less? Or leave it as is? Is the high screen voltage causing the tube to pull more current than I was expecting and thus solely responsible for the higher cathode voltage?
If you've read this far, thanks! And if yer able to help, thanks again!
