I play enough to record bass tracks for my own songs. I do play with a felt pick, never learned to play with just fingers, except when I play two notes at once like a spread 6th.
I'm using a short scale Mustang since I have small hands and short fingers. The main issue I have is the low E usually sounds flabby and loose, especially if I dig in or play it open. The other strings can do the same if I strike too hard on the open string.
I'm wondering if I should move away from the light gauge strings and go to something heavier and stiffer. Would I go up one gauge or two? Maybe get a low E that is still a bit heavier than what comes in the set?
I don't play leads or do bends so maybe using heavier strings won't be a bad thing for me. Thoughts?
