Partscasterer
I wonder if there’s a discernible difference?
not unless you roast them to facilitate latticing of the crystal network.Concise version:
No.
Longer version:
No. It's just 43 or 42 Gauge copper wire. There are a dozen other variables that affect the characteristics of a passive guitar pickup, but copper wire being 'old' isn't one of them.
Sure, but I'll only know after I bought them): I've been eying those for some time https://www.boutiqueguitarpickups.com/mojo-nos-wire-telecaster-setI have a couple of pickups that are close to exact reproductions of vintage pickups that sound just like the originals.
However, I know there are cheaper ones that sound great so there are certainly ones that work at all price points. In the end what really matters is that they sound the way you like.
Just look at what happened to pop music, isn't it exactly the case?I don't really have an answer. I can see how using wire that matches the composition of the vintage wire used in the originals would be a good thing but I don't see why new wire that's made to the identical specifications of the old wire wouldn't work. It's just wire. I do believe in the use of vintage caps and other parts to create tonal matches to the originals but wire? If we can't make wire that's identical to wire made in the '50s we've progressed into regression.
The composition of the coating makes almost no difference. It's the thickness of the coating that does.
It's not just that - it's also that a bigger coil has lower capacitance.It's only the thickness. 1,000s of turns of a thicker material = bigger coil = higher inductance = lower resonant peak in the curve = it sounds a tiny bit different.
