Non Tele Headstock Repair?
Discussion in 'Tele Home Depot' started by iocari, Aug 8, 2012.
  1. iocari
    iocari TDPRI Member
    Stoke-on-Trent, U.K
    Hi Folks i've bagged myself a Yamaha RBX270J from eBay for £16, it's needs a bit of work (Re-Fretting, New Electrics etc) nothing major apart from it looks like the previous owner has part drilled into the headstock
    any ideas on the best ways to repair this?
  2. guitarbuilder
    There are a number of ways and here are just a few ideas. I can think of more like turning down a black dot on a lathe, but I won't get into them :).
    Fill the hole and level sand with a wood putty, epoxy,or plastic wood type material. Use a sharpie to color the top black. You could also fill the hole with a dowel that fits, and glue it in and add some black super glue ( stew mac sells it) to the gaps and top. Level sand it all and maybe add some black super glue to the top of it, and finish with some clear superglue or drop fill some lacquer. Unless you prep and paint the whole surface, you may see telltale signs of the repair. I've taken ebony sawdust and mixed it with different materials like two part epoxy for things like that too. You could even put some filler in and top it off with black super glue that is slightly raised above the surface and then wet sand it back.
    It pretty much comes down to how fussy you want to get with it.
  3. oramac7891
    oramac7891 Friend of Leo's
    Fill the hole with wood filler, tape sand smooth, put a cool decal or random little metal badge over the place. It will personalize it and also give you rationale to deface a guitar with a sticker or such ( not trying to hurt anyone's feeling, there are some people that don't enjoy stickers on guitars, if you one of these people, it will allow you to do something different.)
  4. joshwertheimer
    joshwertheimer TDPRI Member
    Brooklyn NY
    If there are dots on the fingerboard, install a matching dot in that hole.
  5. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    Just darken the hole with a permanent marker.
  6. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
    How about filling the hole with ebony colored Timbermate putty?
  7. jimdkc
    jimdkc Friend of Leo's
    Independence, MO
    This!
    Or just leave it alone... adds character!
  8. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    drill all the way through and use it to hang it! :lol:
  9. alexlaguna29
    alexlaguna29 Tele-Holic
    Atlanta, GA
    Unleash the Sharpie!
  10. LocustPlague
    LocustPlague Tele-Holic
    Melt wax inside. Paraffin. THE WAX GIVES THE TONE.
  11. Bentley
    Kelowna B.C, Canada
    With my experience, sharpie will look different. sharpie looks kinda odd on wood, and it won't match the finish. Nail polish might work, or craft paints.
  12. guitarbuilder
    Got a lot of experience in that area eh?:)
  13. Bentley
    Kelowna B.C, Canada
    hehehe...
  14. iocari
    iocari TDPRI Member
    Stoke-on-Trent, U.K
    i've filled it today with a wood glue and fine sawdust mix gonna let it dry 24hrs and see how it looks after that.
  15. customxke
    customxke Tele-Meister
    philadelphia
    Black marker isn't black....it's dark purple usually.
  16. trev333
    Coolum Beach,Australia
    a cubic zirconia glued in?.... for that added sparkle onstage,,,;)
  17. Jack Wells
    Albuquerque, USA
    Too late now but if you had followed my earlier advice, you could have told people it was a 'tone divot'.
    Now that is a really good idea.
  18. R. Stratenstein
    Loganville, Ga.
    Some sort of inlay? Big dot?
  19. Nick JD
    Queensland, Australia
    I'd cut the end off, removing the problem. When unsure of a solution I always go with amputation.
  20. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    That was my thinking too, til I got down to my last 3 fingers.
