NON-STANDARD MEASUREMENT UNITS
jedediahd
California
So, as a surveyor, we have all kinds of units of measure:
-Chains with 100 links per chain. 1 Chain= 66 feet.
-US Survey Feet where there are 12 inches per foot and 39.37 inches per meter.
-International Feet (SI Foot) where there are .3048 meters per Foot.
-Miles where 1 Mile is 5280 Feet.
-Meters (SI).
-Varas where 1 Vara is 33 1/3 inches (in Texas anyway).
-Acres where 1 Acre is 43,560 square feet (10 square Chains).
-Section where 1 Section is (nominally) 1 square Mile, 80 square Chains, 640 Acres.
-Township where 1 Township is (nominally) 6 square miles.
-Azimuth where there are 360 Degrees in a circle with 60 Minutes per Degree and 60 Seconds per Minute (DMS).
-Bearings where the circle has 4 Quadrants of 90 Degrees. NE, SE, SW and NW.
Anyway, there's more, but I digress because these are all Standard units that we use and the OP wanted non-standard units. We use the "frog's" hair and other hair technique some or just "touch it left/right/away," and the ever important: "can't see it from my house."
The one unit we don't use is inches. Per my first boss: "We don't use inches. Those are used by carpenters and hookers. We use decimal feet around here."
ClashCityTele
Washington, UK
I never understand fathoms, knots, cables & nautical miles.
Must be confusing when an aircraft (using miles, miles per hour & miles per gallon) is landing on an aircraft carrier that is so many nautical miles away doing so many knots per whatnot.
Rusty Spanner
Beautiful Downtown Burnley
New York 'blocks' would appear to have no relation to geography.
'Down a coupla blocks' could be a few yards or half a mile and no relation to what's actually on the ground.
Mind you, Ireland's worse.
'Just down the road' could mean anything.
notmyusualuserid
In the South
Aircraft speed is in knots. The ground speed is mph. Both ships and aircraft measure fuel consumption in range per tonne, and distance in nautical miles. 🙂
BFcaster
Iowa City IA
And to our UK-bretheren, what the heck is a stone?
And I can't fathom a fathom, but I can understand knots. Still trying to work out nautical miles...similar to "as the crow flies"???
BFcaster
Iowa City IA
lol, this one just came to me-
Back in college, where the intellect flourishes, we'd be at a bar and refer to a woman's beauty as 'beers'. Pretty ones were beers for courage to talk to her, ugly ones were beers to actually take her home. You get the picture.
aging_rocker
Aotearoa
A lot of the 'olde' English measurements came about because of trying to combine Roman units with the next lot of invaders (Saxon) units, all over the top of the original pre-Roman units.
Then the Victorians decided to attempt to 'standardise' it all as the Imperial System...and then we went Metric.
I'm still confused.
BFcaster
Iowa City IA
I actually prefer metric for small things, like string height/action and even distance in some cases. What confuses me, as a long-time BBC America viewer (Clarkson's Top Gear), and Escape to the Country as well, is that sometimes you Brits use both. Do other common-wealth countries use both? Australia, New Zealand, Canada, territories in the Caribbean??
