Non Reverse Build (very slow)
Discussion in 'Tele Home Depot' started by Jake Nelson, Sep 19, 2019.
  1. Jake Nelson
    Jake Nelson Tele-Meister
    Bemidji, MN
    I have posted a few times on my favorite thread, what’s on your workbench and someone said ‘lots of cool projects going on, how about some build threads’ so here goes my first build thread (not first build)
    a year ago:
    I acquired some old fir that was removed from a barn and had been in storage for more than 25 years so it must be close to 100 years old. Made a 3 piece body.
    that end grain though :)
    (bottom one)
    PingGuo, nnieman and Fretting out like this.
  2. Jake Nelson
    Bemidji, MN
    Next I made a router template for the chambering
    hogged a pile out with a forstner bit
    started smoothing with the router and template
    (i don’t have a pic of the smooth inside)
    zammie likes this.
  3. Jake Nelson
    Bemidji, MN
    top is some cherry that was given to me a few years ago
    PingGuo and Jim_in_PA like this.
  4. Jake Nelson
    Bemidji, MN
    then i sanded the edges, mostly with a belts sander, i didn’t have my spindle sander yet. the inside curves near the neck pocket weren’t totally square, kinda rounded a little bit from hand sanding, which made cutting the binding channel interesting. next build i will use the spindle sander for sure!
    routed the neck picket (after making a jig with the 3 boards clamped around the neck trick)
    then placed the bridge and drilled the top part of the string threw holes
    GoKart Mozart likes this.
  5. Jake Nelson
    Bemidji, MN
    next i started on the pickup routes
    FYI next build i will do edge sanding and binding then pickups and bridge and stuff ...
    ordered a humbucker template on ebay and it wasn’t on a vary big square of wood so made a bigger template with it
  6. Jake Nelson
    Bemidji, MN
    sometime after that i routed the control cavity access
  7. Jake Nelson
    Bemidji, MN
    then i did the string ferrules
  8. Jake Nelson
    Bemidji, MN
  9. Jake Nelson
    Bemidji, MN
    all i have time to post right now...
  10. gkterry
    gkterry Tele-Holic
    the Telecaster Forest
    Very, very nice! Can't wait to see this all the way through. The ferrule holes look perfect.
  11. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    Neat work so far ;)
  12. Jake Nelson
    Bemidji, MN
    this is the inspiration to start this thread
    thanks @Barncaster
    crazydave911 likes this.
  13. crazydave911
    East Tennessee
    Nice!
  14. REWTX
    REWTX TDPRI Member
    DFW
    That's awsome
  15. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    cool
  16. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Great work. I'll be following.
  17. Jake Nelson
    Bemidji, MN
    then this thread was created :confused:
    https://www.tdpri.com/threads/stewmac-router-oops.951906/
    after i did the ferrule holes i drilled the output jack hole... not a good idea because when i was routing the binding channel the guide fell into the output hole...
    so i said it before and i’ll say is again, mostly so i remember, edge sand then binding then the rest!!
    this is the setup i used
    then the idea was given to drill it out and plug it.
    thanks @guitarbuilder !!
    got a 3/8 plug cutter at the local surplus store
    the scrap of cherry that i had to make a plug from was less then a 1/4 thick so i couldn’t get a clean cut so i clamped it between 2 pine 1x4’s and it worked
    all plugged up ...
    guitarbuilder likes this.
  18. Jake Nelson
    Bemidji, MN
    then it was binding time! binding adds a lot of work but it’s what makes a guitar awesome in my book. a sweet guitar without binding isn’t near as appealing.
    and no that is not a spanking paddle, it’s my strop for my chisels n knives n such. has leather glued to the other side.
    zippofan likes this.
  19. Jake Nelson
    Bemidji, MN
    then sand, sand, sand...
  20. Jake Nelson
    Bemidji, MN
    then i started a totally new deal, my brother had a detail gun that he wasn’t using (and now that i have tried it he’s not getting it back:D:D)
    then some shellac sanding sealer
    tintag27, zammie, PingGuo and 4 others like this.
