sean200000
Ok thanks, i'll check them outMy one must be a later version then.
All resistors can be a source of noise. Wire wound are least noisy, then metal film. I generally use these in all small signal applications.
If the noise in your amp is random/pink/white spectrum, blame the resistors.
Totally possible to keep the origionals if carefully removed, when swapping in newer ones for an experiment.
