sean200000
I'm trying to fix up an old version 1 Fender Pro Junior that has basically been sitting in a cupboard for 20 years. It is really noisy, with the volume above about 2 its basically unusable because of a loud water-rushing type sound.
So far I have tried:
Removing the top middle screw on the back panel (this helped a lot with the base level hum)
Twisting the green heater wires (made no difference)
Replacing the first filter capacitor with a 100uf capacitor and replaced all the other filter capacitors (maybe a little improvement)
Swapped both preamp tubes with a number of different 12AX7 and 12AY7s (no change)
With the first preamp tube removed the noise goes away, but its not the tube as I have tried different ones in the same spot.
I know the Pro Junior has a reputation as a noisy amp which i'm fine with but this one is way noisier than it should be.
Any ideas?
Any ideas?
