Nocaster PUPs
Discussion in 'Fender Custom Shop Tele Forum' started by vishnu, Jun 4, 2018.
  1. vishnu
    vishnu Tele-Meister
    scotland
    In my 2016 52 CS
    I set the PUPs up as per Fender's recommended height for "vintage PUPs" and the difference when switching between PUPs is quite pronounced with the bridge being a shade or two LOUDER
    Anyone find this with the Nocaster PUPs at all?
    Thing is peeps, when I try to lower the bridge PUP the bass side screw does not appear to be working....
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    That is normal. The neck pickup in a Telecaster is notably lower in output and that goes back to it's design. Is this the original Nocaster or the newer model with a Twisted Tele pickup? Which switching do you have?
  3. vishnu
    vishnu Tele-Meister
    scotland
    it's the 2016 CS with a pair of Nocaster hand wound 51s
  4. Mr.Ike
    Mr.Ike Tele-Meister
    Albany,NY
    You can get them dialed in, don’t go by what you see, let your ears be the guide. Those are one of my favorite pickups.
  5. vishnu
    vishnu Tele-Meister
    scotland
    if for whatever reason I can't get the bridge lowered any more due to screw problem I could always RAISE the neck PUP beyond fenders recommended specs with no ill effects?
  6. rze99
    rze99 Poster Extraordinaire
    South London UK
    Yes I have that set and the neck is quieter.
    I set both pickups quite high and don't get magnet pull issues. I most use a compressor and that helps balance them.
  7. Iago
    Iago Friend of Leo's
    Brazil
    Don't be afraid to set that neck pickup higher!
  8. Dacious
    Godzone
    With your strings fretted on the 21st fret your bridge should be a couple pennies 2-3 clear treble side, 3-4 in the bass.
    Does the bridge pickup push down - presumably you have the screwhead protruding from bridgeplate? If so the surgical tubing mounting it has compressed.
  9. vishnu
    vishnu Tele-Meister
    scotland
    Is that a big deal? ^
    I don't want to touch the bridge PUP again as it looks fine , it raised fine but wont go down, and yes, the screw head sits proud of the plate if I attempt to lower the PUP
    ( I have the screw head flush with the plate at the mo) and no, the PUP does not push down
    fenderchamp likes this.
  10. Dacious
    Godzone
    No, but the tubing sticks to the plate, compresses and doesn't push the pickup down. So when you loosen the screw it holds it up instead. Replacing the tube is easy but you have to remove the bridge plate.
  11. vishnu
    vishnu Tele-Meister
    scotland
    thanks guys :)
