No voltage at position 18 Mojotone 18watt tmb
dsutton24
Illinois
Your soldering needs a little work in a few spots, but on balance you've done a pretty respectable job on that thing. On the next project you should allow some space between resistors, and also some space between resistors and other components like capacitors and wires. Some of those resistors get pretty hot.
Martinoils
Tucson, Arizona
Thank you, much appreciated!
Martinoils
Tucson, Arizona
From reading the earlier post I see that you have reflowed pin 7 on the sockets. Many of your turrets also appear to be lacking solder which could lead to poor electrical contact. If you are having trouble getting good solder joints on the turrets, you may need a larger tip for your iron to help heat them properly.
Thanks I’ll correct that!
Martinoils
Tucson, Arizona
Martinoils
Tucson, Arizona
I'm scoring Andrew a hit. Martinoils, you know which tube is the LTP? Heh, the one that's supposed to have a jumper from pin 3 to 8. :) But that's V3 if I'm counting right.
I’ve been looking at that layout so long I miss everything. Of course that’s V3
I need to take a break but not before I make these corrections tomorrow.
Thanks again!
Phrygian77
Gold Supporter
Crawfordville, FL
The only thing of concern here is the output tubes' cathode cap. It is right on the resistor. That one should be moved. I don't see any issue with anything else.
Paul G.
Rhode Island
The cathode cap resistor is the cement wrapped 130R all the way on the transformer end of the board.
I don't know if this is related to any of your issues, but the lack of solder on your turrets will lead to a very unreliable amp. Put your soldering iron tip on the top of the turret and component lead. Wait a second or so, then touch the solder to the tip, it'll melt into a blob. After a few seconds, the top of the turret will be hot enough to allow the solder to flow onto it. Quickly remove the tip. You should have a solid connection with the entire hole filled and component lead securely embedded.
Martinoils
Tucson, Arizona
Thanks I’ll resolder today. How should the cathode cap resistor be moved? Should it be elevated not sitting on the board or is the cap attached to it too close? Thanks again
Phrygian77
Gold Supporter
Crawfordville, FL
Don't worry about it for now. The point was that cathode resistor gets hot, and it will shorten the life of the bypass cap. You want some space between them.
