No Signal on Bright 1 Input Jack for 5E3
Discussion in 'Shock Brother's DIY Amps' started by James Knox, Oct 29, 2020.
  1. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    My first attempt at using Shielded Cable (and hanging the 68ks) for Input Jacks to V1.
    I followed RobRob...
    Here are my pics...
    26796749-1F16-4549-8356-9EA347386D04.jpeg 5494764F-366F-413E-9D37-09F778C25CF4.jpeg
    Grounding only at the Jack side and NOT at the Tube...
    All three other jacks work correctly. I first thought that maybe the ends of one of my 68k was grounding against the shielding so I made another lead making sure that was not the case prior to shrink wrapping.
    I did it like this...
    When I measure tip to sleeve on a guitar cable plugged in I get these readings:
    Normal 1- .634M
    Normal 2- 130K
    Bright 1- 1.1 ohm
    Bright 2- 125 K
    I triple checked over all of the resistors (68k and 1M) all in spec.
    What am I overlooking?
    Thank you!
  2. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Looks like you're missing your signal connection from bright 1 hi to bright 2 lo.
  3. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    Your bright 1 resistance measurement indicates a short.
    James Knox likes this.
  4. Peegoo
    Make sure the switch on the jack is opening when a plug is poked into it.
    Junior Little and James Knox like this.
  5. James Knox
    Phoenix
    Sorry for the blurry pic, but the connection IS there...
  6. James Knox
    Phoenix
    Yes, I did check that.
  7. James Knox
    Phoenix
    a short, like as in the resistor is bad?
  8. D'tar
    D'tar Friend of Leo's
    WNY
    :rolleyes:
  9. Lowerleftcoast
    california
    1.1 ohm meter reading indicates continuity. A short.
    The shield is touching the resistor lead or inner signal wire.
    The jack switch grounds the signal.
    Something like that.
    D'tar and James Knox like this.
  10. James Knox
    Phoenix
    Found it! Thank you Brothers...
    sds1, D'tar and Lowerleftcoast like this.
  11. D'tar
    WNY
    Ahhh....
    The Blob!
  12. James Knox
    Phoenix
    Hahaha - just when I thought I was getting pretty good at my soldering chops!
    sds1 likes this.
  13. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    These are $15 and totally worth it! I bought them for SMD work but I use them for soldering inspections now too. These will keep ya honest!
    https://www.amazon.com/gp/product/B071GWM9QN/?tag=tdpri-20
