No saddles?
Discussion in 'Bad Dog Cafe' started by Marc Morfei, Dec 27, 2019.
  1. Marc Morfei
    Marc Morfei Tele-Afflicted
    Philadelphia, PA
    How do you intonate a guitar that has no saddles? I am looking at a Gibson Les Paul Junior Tribute, and it has no saddles, the strings go straight to the bridge. It's a compensated bridge, I can see that. But still, how do you adjust the intonation? I searched all over the web but amazingly could find no answer. All the other Gibsons seem to have individual saddles. Advice? Would this guitar just be a PITA?
  2. mabinogeon
    mabinogeon TDPRI Member Silver Supporter
    Upper Michigan
    With those screws you can see poking out the bottom of the bridge.
  3. viking
    viking Friend of Leo's
    Denmark
    You only have the option of moving the whole bridge at either side , as said
    There are , off course , hundreds of aftermarket solutions ready
    Generally , these models aren't known for super intonation
  4. brookdalebill
    Austin, Tx
    You’ll need an Allen/hex wrench to adjust the bridge assembly.
    It should intonate perfectly with common string set gauges.
  5. Marc Morfei
    Philadelphia, PA
    Ahh, I see. Got it. Thanks. So you can't adjust each string. Hmm.... not sure if I like that. Of course I suppose tele owners get along just fine with all those 3-barrel vintage saddles. So I guess close enough is good enough,\.
    colnago likes this.
  6. Frodebro
    Seattle
    I've got the dual pickup version of that guitar. I'm pretty nitpicky about intonation with my guitars, and this one doesn't give me any issues.
  7. Marc Morfei
    Philadelphia, PA
    Overall how do you like the guitar? They have one used at my local GC, and it played and sounded really nice. Light as a feather, too.
  8. Frodebro
    Seattle
    Running 10-46 on it.
  9. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    If you do feel you need to adjust one side or the other of that bridge rearward by tightening those tiny grub/set screws, I'd suggest loosening the strings and making small (1/4 turn of the screw) adjustments and then retuning and checking. There is a lot of tension on that stop tailpiece/bridge, and there is a chance that the screw threads could strip if tightened with full full string tension applied.
    I had a Hamer USA Special shaped exactly like that Gibson and found it to be uncomfortable to manage when playing seated. The body shape just would not balance well for me. You should certainly try one, or something similar, at a local store before buying it to see how it "fits" you and your typical playing position, seated vs. standing
    nojazzhere, bumnote and TheGoodTexan like this.
  10. TheGoodTexan
    TheGoodTexan Moderator Staff Member Ad Free Member
    Nashville, TN
    As has already been said, unless you’re using an oddball string set, you can pretty much nail the intonation with a wraparound bridge that has the two set screws on the back.
    I had a friend who played slide on a LP Jr, and used a super heavy plain D string (like a plain 24??) rather than a wrapped string. He couldn’t get that one intonated too well for fretting up high, but it worked for slide. Other than cases like that, there is nothing wrong with those bridges.
    Jackroadkill and MrGibbly like this.
  11. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    And archtop owners get along just fine with floating bridges. Intonation on a guitar is a heap of compromises. No reason that won’t work fine. Also, Juniors only look right with those bridges, IMHO.
    nojazzhere and TheGoodTexan like this.
  12. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Wrap tails are "close enough for rock n roll!"
    The "lightning" ridge line on top of the wrap tail sets up the intonation pattern, small adjustments are done on the bar from side to side depending if you are using 9s or 10s.
    It generally works pretty well.
    Look up intonation of nuts (buzz feiten system) and the microtonal or fanned fret fretboards out there if you are really zeroing in on intonation improvement desires.
    If you get a wrap tail guitar and you can't get it intonated, there is a design called "bad ass" that is a wrap tail with individual saddles you can move.
    Marc Morfei likes this.
  13. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Just remember that almost all acoustic guitars operate the same way. There are no individual intonation adjustments for each string.
    colnago, MilwMark, Jim603 and 4 others like this.
  14. vgallagher
    vgallagher Tele-Meister
    Knoxville, TN
    It’s kind of like a compensated acoustic guitar saddle but with adjustment. I would think you could tweak it in pretty close to perfect.
    MilwMark likes this.
  15. jonnyfez
    jonnyfez Tele-Afflicted Silver Supporter
    Kittery, Maine
    I have an SG special with that bridge. No issues. A Les Paul with a slanted wraparound from Mojoaxe. No issues. A vintage Gretsch 6120 with a straight bar bridge. No issues. It's all close enough. Les Paul played with a wrap. Chet Atkins played with a straight bar. Sounded pretty good to me.
  16. 8trackmind
    8trackmind Tele-Holic
    Memphis, TN
    Had to post because I have one too...
    Fendereedo and Frodebro like this.
  17. nojazzhere
    Foat Wuth, Texas
    Hard to see on this photo (only one I have at the moment) but I put a Leo Quan "BaddAss" bridge on my 1960 Jr. Each string has an adjustable saddle, like a Tune-O-Matic. My PRS SE One has the "lightning bolt" type bridge (fixed) and it intonates just fine.
  18. cometazzi
    cometazzi Tele-Meister Silver Supporter
    Das Land von Käse und Bier
    I've got something similar. I'm less successful in getting it intonated. I've looked at the wraparound bridges with saddles that you can buy aftermarket, but from what I've read it sounds like they raise the action significantly, so I haven't tried it.
    This guitar and my AC-15 are in *love* with each other, though.
    nojazzhere likes this.
  19. Chunkocaster
    In space with Ziggy
    They have more room for intonation adjustment than most acoustics. I don't hear any intonation issues when playing my acoustics.
    beagle and nojazzhere like this.
  20. nojazzhere
    Foat Wuth, Texas
    Back in the 50's, 60's and 70's, there was an old guy here that was primarily a violin maker and repairman, but he also carved rosewood bridge saddles for acoustics. They were NOT adjustable, but fixed in what was generally the correct position for good intonation. He then cut out of the bridge where this "saddle piece" would sit. The last one he did for me (a Yamaha FG 160) in the early seventies, he was in advanced years, and his skills were failing him. I had to take the bridge, and cut down the "saddle peak" for one string, and then glue in a different "peak" so that it would play in tune.....but after that, it was fine.
    Chunkocaster likes this.
